Making new def for BE
Can someone please help me by pointing me in the right direction as to how to go about creating my own def file on BE. I'm in Australia and our EECs have near to no support at all. I'm running the tweecer and some guys here have hacked the EEC I'm running, but they're not using BE. They're running the moates gear and tunerpro. Because I have the tweecer already, I want to try and use that still and hopefully help out a few guys over here with the same EEC as me.
Thanks in advance for any help.
STREETBUILT RACING
Aussie 302w [YEAH NAH] EL XR8 with Trick Flow top end kit, 70mm tb, 73mm maf, 24lb injectors, tweecer, 3.73s & tired T5 = 275rwhp & 13.155@105mph NA. 12.375@116.73 N2O
3700lb with driver
Strategy - NVMG84 EEC - 6DFC
3700lb with driver
Re: Making new def for BE
It's ok, I've found the definition template. Now to work out what goes where...
STREETBUILT RACING
3700lb with driver
3700lb with driver
Would changing the EEC to one of the more popular ones discussed here be an easier or more practical solution? Maybe there is a strategy/calibration here that is close to yours. What is your catch code, year of vehicle etc.?
As far as I know, our wiring looms and your eecs aren't compatible.
My car is a '96 Ford Falcon XR8. My catch code is 6DFC. I think I've found a way to cheat by using the GUFB strategy, finding the same PIDs and changing the address. Does anyone know if this will work or if I'm wasting my time?
A guy I've just started chatting with has found a lot of parameters in the 6DFC using hexplorer by using the GUFB def to compare his findings with, so all the names of everything are the same.
STREETBUILT RACING
3700lb with driver
3700lb with driver
- 86GT
- BE/EA Developer
I just uploaded the new template sorry it was not the most recent. BE version 2.3.1 Added some new columns that support new features. If you have an XDF from tunerPro it can be converted with BE to get you a good starting point.
Thanks 86GT, that's what I'm actually doing now. It's a slow process, but is easy enough.
I can see many hours going into this, but be well worth it.
STREETBUILT RACING
3700lb with driver
3700lb with driver
- 86GT
- BE/EA Developer
the conversion is quick is that what is taking you a while because BE will open the XDF.
Sorry, I'm not too sure what you mean conversion...
What I'm doing is this. I have tuner pro opened with the NVMG8.xdf and 6dfc.bin. I also have the gufb excel worksheet open which is the strategy for BE. I then did a save as and saved that as 6DFC. What I'm doing now, is selecting the parameters in tuner pro, hitting f2 and all the info comes up. I then copy the PID and use the "find" function in excel where it finds the parameter for me. I then cut and paste the address from tuner pro to excel and move on to the next one.
Is there an easier way to do it than this? Please tell me there is.
STREETBUILT RACING
3700lb with driver
3700lb with driver
If you already have a TunerPro XDF file, then just import the XDF directly into BE so BE displays the definition like TunerPro does. From there, you can save the definition in BE to be in XLS format and edit it like the GUFx defs.
To do this, click OPEN Definition, and from the dropdown box in the browse window, select the TunerPro XDF instead of the BE XLS file format.
- 86GT
- BE/EA Developer
Just as Chris said.
If you have any problems send me the XDF and I will convert it for you.
When I open BE and the xdf, a dialogue box comes up asking me how many banks as follows.
XDF Address Offset
Enter the address offset
For a 1 bank tune enter 8192
For a 2 bank tune enter x
For a 4 bank tune enter x
It is written just as I have written it above. Because I have no values for 2 bank, which it is, I have to set it to one bank. Then once it's open it has a bitch about the levels not being set right. Then, when I open up the 6dfc.bin, another dialogue box comes up, saying "the normalizer has no value in column index 0. Make sure the normalizer has not been filtered out and that it still exists.
Once I hit ok a couple of times, it opens the bin, but all the values seem to be maxed out. After saving it and then opening the new .xls everything is very different to what I've been looking at with the gufb.xls that I've been modifying.
If you want to have a look at it, the link to get the nvmg8 def is at the bottom of the Ford listing at http://www.tunerpro.net/downloadBinDefs.htm
You'll also find the 6dfc.bin there as well.
I'll just keep modifying the GUFB for now.
Thanks for your help
XDF Address Offset
STREETBUILT RACING
3700lb with driver
3700lb with driver
Send your XDF and BIN file to Clint (86GT) so he can look into why the import isn't going more smoothly. That's the whole purpose of the feature is to make the transition to BE from TunerPro smooth. If that's not happening, he needs to know about it so he can correct it.
Please excuse my ignorance, but is Clint the developer of BE or something?
Is that link sufficient, as it has both the bin and XDF there? Or do you want to give me an email address so I can send it on?
Chad
Chad
STREETBUILT RACING
3700lb with driver
3700lb with driver
Yes. Clint (86GT) is the developer of both BE and EA...a very valued member of this board.
Great, I should have begun asking questions a long time ago then!
STREETBUILT RACING
3700lb with driver
3700lb with driver
- 86GT
- BE/EA Developer
Yes i am Clint and will help with the import
Thanks Clint, I appreciate it.
STREETBUILT RACING
3700lb with driver
3700lb with driver
Gday All
Ive been helping Scaffy with his Aussie ECU, as Im running the same ECU, and Ive been using TunerPro with the Moates Ostrich, Emu, Burn1 combo and F3 chips. Im quite the fan of TunerPro, however BE and EA do seem to have a hell of a lot more stuff that can be done ie heaps of RT datalogging options with the right hardware, and Im keen to work with both, as Im not a fan of CalEdit/CalCon.
From the info above, Ill also have a go at converting the xdf to xls via BE, and see how it pans out. Ive only downloaded BE last night, but already Im very impressed, and I really love the idea of user friendly definition creation, which has been a little difficult with other GUI tuning software packages. Keep up the great work Clint!
Jaysen
Jaysen
Unlike with other tuning softwares (TunerPro included), BE is constantly being updated with new features...some in-your-face features that make the user-experience much better, and some definition developer features that the average user will never see. Clint's been very receptive to the needs of both the users and of the definition developers. It's just unfortunate that decompiling and reverse-engineering isn't any easier.
- 86GT
- BE/EA Developer
The idea is if the user interface is easy enough the users time can be spent on the reverse engineering of the tune rather than having to fight the tune and the user interface.
Jaysen
Let me know if you have any trouble converting the XDF files. I can help or even convert it for you and send it back via email
Jaysen
Ive been playing with this for a few hours now, but still fighting with it. What I think my problem might be is that our Aussie EECV's are a 256k 2 bank bin, with the code starting at 0x22000, and the parameter data of this particular bin starting at 0x2A000. Im aware that the EECV's you guys use in the states have thier parameter data starting at 0x12000, which could be part of my prob as it doesnt seem to have all the parameters, nor are they in the right place. When I open the Explore Binary button, I should see my catch code and strategy at 0x19F06, but instead its found at 0x15F06, where did the 0x4000 data go?
I might take you up on the email option if you dont mind Clint?
Jaysen
Jaysen
- 86GT
- BE/EA Developer
sure send me the BIN and the XDF and I will take a look
- 86GT
- BE/EA Developer
The other thing to note is what is the offset in tuner pro. If you hit ctrl F2 there is a offset there. I need to know what you have it set to.
Clint
My base offset is set to 0 as I thought that it might effect my ability to RT tune, Ive not tried it with a different offset.
Ive sent you an email to Clint@EECAnalyzer.net
Jaysen
Jaysen
Cheers for the files Clint.
I've just discovered a problem in BE, more than likely due to my stupid need to press buttons when I don't know what they do. I opened a tab in BE and there was something about LC1 in there. I clicked a button to do with LC1 and it came up saying no mts port available, then shut BE down. When I try and open it up again, it just shows the dialogue box saying the same thing and doesn't open. I Uninstalled the re-installed and it still does the same.
STREETBUILT RACING
3700lb with driver
3700lb with driver
- 86GT
- BE/EA Developer
once you open BE goto the hardware tab and disable the LC1 and the error will go away. The reason you are getting the error is because the PC does not have a com port.
BE doesn't open. All it does is come up with the dialogue box, saying no mts port available or whatever. I hit ok or close it and that's it. It doesn't continue to open.
STREETBUILT RACING
3700lb with driver
3700lb with driver
- 86GT
- BE/EA Developer
In the BE directory there is a folder called CONFIG. Open that and delete the LC1.xml file and then try that. If that does not work then delete the entire CONFIG directory and try it again.
Users browsing this forum: Bing [Bot] and 117 guests
