I told you it's usually something stupid.dsblk93gt wrote:bender460 wrote:
So going off that pic it looks like it is mounted backwards....the plug should be at the top not facing down..
Nice pic to make it clear for everyone
tremec77 wrote:I took a look at your tune and I would lean out the MAF curve 5% at a time. You have some really high numbers there and this is probably why you are seeing just a rich condition. Granted you are running a turbo and you are going to have higher numbers but I just think you have them too high to start with. You may have to lean it out a lot to get it to run good. Since you have a wideband, force OL and clear your KAMRF's. Then flag accel enrichment (AEFUEL) and transient enrichment (EFTRFF) so you can filter these out. Then go drive the thing around and run that log through EA. Be sure when you run the log through EA that you have the MAF curve that was in the car when you logged or you will be chasing your tail. Don't go WOT until you get the low and mid range running good. You may have to increase the numbers back up later to dial in the A/F.
Glad to see it is running good now!!!turboffr wrote:Thanks again everyone! Guess there's a first time for everything![]()
I must say it runs 1000% better now and I just got a nice highway cruise datalog in open loop to run through EA and starting Tweecin' it.
Ahhh..ok.Cougar5.0 wrote:Let me straighten this out before another rumor gets going on the internet...dsblk93gt wrote: I've heard of issues with the adapter harness on the PMAS.
You posted in that thread but must've missed the second to last post where the PMAS dude told Bob they had fixed the problem.Originally Posted by flyin_hawaiin
that doesnt happen with the adapter plugs that i sell.. they are all sealed up!
Reply by awdgst (PMAS)
We fixed that problem a while ago, and replaced any mafs that had problems...
Users browsing this forum: No registered users and 177 guests
