madramper
Going supercharged, what needs to change
Post by madramper » Sun Feb 22, 2009 8:23 pm
I don't have much experience with mass air. Does my tune have to change when I put the blower on? If the meter measures the amount of air passing through it, then shouldn't it automatically add the fuel for the amount of air? I just want to be prepared before I put it on.
Thanks!
Black 93 Lightning #4396 - 7-2-93
Stock Bottom End - 75k miles
Custom Ed Curtis AFR 165s
Trick Flow Stage 2 Cam
Pro-E mass air
Circle-D 2800 stall converter
Punished E4OD
My own 1 3/4" longtubes
My own CAI
Power adder: size 13 right foot!
Some other junk
Re: Going supercharged, what needs to change
Post by cgrey8 » Sun Feb 22, 2009 8:31 pm
If the MAF measures the air, it'll match that. But what you do have to deal with is the fact that the stock tune tops out at 75-80% load. But with a boosted application, you'll go well into the 120-150% load if not higher depending on your level of boost. So you'll need to rescale your various tables to accommodate boost levels that high.
Users browsing this forum: No registered users and 100 guests
