moosejaw
ISC airflow scale for a9l/a3m1 etc
Post by moosejaw » Thu Aug 14, 2003 12:36 pm
Can this scale be expanded beyond the 2.0 pounds range? After data loging and calculating for my new neutral idle airflow function I discovered I am off scale at 1000 rpm. What is interesting is the Dashpot Preposition accepts large values but Drive/Neutral Idle Airflow do not.
I am using a 3.5 Univer @ 42# blow thru 2 linear feet from throttle(Leaned 11% to remove Pro-m enrichment). I have a stock throttle. I have a large blow-off before the meter which helps keep inlet pressures down during idle.
I think everthing is OK I just need to have this function rescaled but I can't locate a means to do it. Is this a dat setup change?
edit: OOPS! I am now using an A3M1. The A9L died this past weekend. Gottta change the sig.
Mike
'90 LX Low Compression 302, ATI P600B (no intercooler), G-Force T-5, 42# Injectors/ Univer Meter, T4MO Processor J4J1 strategy, Tweecer RT,
(not so) painless engine harness.
Track heat heads, R intake, stage 2 cam, stock throttle body.
460 rwhp
gt90stang
Post by gt90stang » Sun Aug 17, 2003 12:57 pm
Hi,
I am interested in this also. I don't think you can move the max. maybe Mike can. I extrapolated to as close as possible and kind of smoothed it out a little. Seemed to work for me, but it would be nice to get it closer. My main issue was with ISC neutral idle airflow function. For me I think it works ok because I idle below were I ran out of range.
Don
1990 GT, A9P, v1.30A9, 306ci, 76mm C&L, Explorer (GT40) lower, KB Blowzilla 8#, 42# inj, Edelbrock 6037 aluminum heads 2.02 / 1.6 valves, Crane 2030 cam...way more.
moosejaw
Post by moosejaw » Mon Aug 18, 2003 11:07 pm
Yeah, its kind of hard to smooth it out when it goes off chart so quick. But I have found tilting the zero RPM point upwards .3 -.6 air helps keep it somewhat linear in the useful range.
Now to keep the contacts clean. :?
Mike
460 rwhp
moosejaw
Post by moosejaw » Wed Aug 20, 2003 12:23 am
I can report a better idle now. It seems that making dashpot adjustments and restarting may have been affecting learned values even if I had flushed the KAM 10 min prior. This thing learns fast. Faster than I ever thought it could. To get baseline idle values locked down good it seems that a kam flush would be proper after each dashpot adjustment.
I did another datalog of the idle and 650-2000 RPM points then diddled with the dashpot and reset kam. The car started and idled 3 times straight but could not support AC right away. I then drove 15 min and 7 miles home. Idling in the driveway I turned on the AC with no problems. Small bumps of the gas were not a problem.
I like the new idle values and will save them to insert into better tunes. BTW base idle was 650 RPM avg. with a pretty descent cam.
Mike
460 rwhp
Users browsing this forum: Google [Bot] and 43 guests
