StangCrazy
Newbie to Tweecer?
I don't even know where to start and how to get programs that I can program the computer. Please give me some guidance.
MAYHEM1
new tweecer user
go to tweecer.com and go to downloads and download all the files available, put the files where they are routed to the usually go to program files under stkr folder and then open the caledit file and start changing parameters, but i will tell u have alot of problems with the files and i myself have no idea where to start
StangCrazy
black sunshine
http://www.tweecer.com/downloads.html
download the full Rt setup, and when you get it, it will be the install for both Calcon and Caledit.
86 Gt Mass Air Conversion - gt40x heads, Lunati 51014, power plus intake, 65mm TB, 90mm cobra MAF, full exhaust, 255lb+t-rex, 42lb inj, 3:55's, tweecer, msd BTM
S-trim, AFM Powerpipe, Ramchargers Dual fans
StangCrazy
CalEdit is the interface to make changes to the calibration data and CalCon gives you feedback on what you have changed. You cannot write to the tweecer while CalCon is open so you must close it to access the tweecer with CalEdit. You can keep Caledit open and still use CalCon though.
Best regards,
Mike Glover
Mike Glover
