POPSRACING
New AHACA being released
We are coming towards completion of development on the much anticipated AHACA strategy for the F150 and Bronco guys.
Land and Sea chassis dyno
1995 Cobra, 408, sold...
POPSRACING
Re: New AHACA being released
Anyone located in Rochester with AHACA based PCM, would like to finalize some datalogging variables.
What binaries fall within the AHACA strategy? I have a Bronco EEC, will need to look at the label...
POPSRACING
I know these are:
AKC0 (Lightning Maf conversion PCM)
BIO0
MOB1
I need to look up the hardware code but any pcm sharing that hard ID would also accept AHACA
BIO0
MOB1
You mean apart from the 47 Ford gives you for free for the DCL?POPSRACING wrote:Anyone located in Rochester with AHACA based PCM, would like to finalize some datalogging variables.
POPSRACING
LOL, nice Mike....talk to you in a minute.
Woooohoooo!!!!!We are coming towards completion of development on the much anticipated AHACA strategy for the F150 and Bronco guys.
Also the RAN2, I believe, uses AHACA.
1992 Bronco- details when the new motor goes in.
Not yet tuning, just researching/learning, stockpiling parts.
POPSRACING
It's completed...
393Flareside
I've got a WAY1 that I think AHACA will work on. Not positive, but pretty sure. I'm using the AHACB right now. I'm in the process of hopfully fininshing the tune later today.
'93 Flareside ext cab, 4x4, 393 Stroker, MAF convsion, WAY1 pcm w/QH, E4OD, 4.10 e-locker, LC-1 w/G3, 130amp-3G alt, e-fan, 32x11.50x15
POPSRACING
If the hardware code is SMD-272 then yes.
POPSRACING
RAN2 is also supported.
Whats the cost? Available where?
POPSRACING
PM'd you
Thanks! It'll be a bit before I'm ready to purchase a strat, but I look forward to hearing others' tuning experiences with this new release.
POPSRACING
393Flareside is utilizing it....
POPSRACING
AHACA has been quite popular for the truck and bronco folks.
What exactly is new on this strategy? I am new to this stuff and was just wondering,. I have a BIO0 PCM with the AHACA strategy. I got the one that is in the binary editor I recently purchased. And I got my BIO0 bin file from eecanalyzer.com
88 FullSize Bronco, 393W stroker,JBA Headers,4.56 gears L/S 8.8 rear, 19lbs injectors , Stock Bronco MAF via WAY1 EEC, Moates QH,E4OD Tranny
Adam was kind enough to let me "peek" at the new release via Skype and it is AMAZING, everything is grouped together and really easy to find. The datalogging tables are complete and I don't believe there is anything else that could make it any easier to use.Bman wrote:What exactly is new on this strategy? I am new to this stuff and was just wondering,. I have a BIO0 PCM with the AHACA strategy. I got the one that is in the binary editor I recently purchased. And I got my BIO0 bin file from eecanalyzer.com
I haven't been able to purchase it yet, mostly due to the vehicle being parked for the winter and the tuner that was going to dial my Bronco in, retired. So now I have to find someone else in WA state to tune my rig, until then it will sit.
Anyone in WA state know a GOOD tuner that is familiar with BE?
PLEASE help !!!
Michael Long
1992 "Lightning" Bronco >>almost done<<
1994 Roller motor with TrickFlow Stage I clone cam, GT40 heads, Lightning intake, 75MM TB/EGR spacer, 30# injectors, 80mm MA meter, FMS shorties, AHACA w/ MOB1 Moates QH, Binary Editor, LM-1 And I have NO CLUE what I am doing...
http://s110.photobucket.com/albums/n93/ ... %20Bronco/
POPSRACING
I could assist you remotely with the calibration, we can discuss that at later point.
Regards
Regards
OK, Thx Adam. Craig @ Moates kinda said the same thing, I didn't really know that was possible... I'll talk you in in a few weeks. When it is a little nicer/warmer outside and I'm not hammered with school.POPSRACING wrote:I could assist you remotely with the calibration, we can discuss that at later point.
Regards
Michael Long
jeremymillrood
I've got a '92 Bronco w/a 351/E4OD combo and MAF conversion. I'm running a WAY1 EEC with a Tweecer using the VEX1 strategy and a base calibration tune. I'm not unhappy with the current tune, but I feel like it could still be better. Just to confirm, based on what I'm reading here, I could run the AHACA on my rig with the WAY1. Is that correct?
'92 Bronco, 351W, E4OD w/MAF conversion, WAY1 EEC, VEX1 strat and Tweecer RT...newbie tuner
Keep up the great work Adam.
Mustang408
I've only briefly talked to the guy that does the tuning at http://www.themustangshop.com/dyno.cfm but he said he was familiar with BE.drvovru wrote:
PLEASE help !!!
They are in Auburn.
88 Mustang GT-302, AFR 165, Cobra Intake, Custom Cam .565/.535 LS 109*, 65mm TB, 70mm MAF from 92 Crown Vic, 1.6 RR, FRPP 30# EV1, Shorties 2-1/2 full exhaust, T5, 3.55, A3M1.bin, TwEECer, BE, EA, AFX/NGK WB-O2, Data-Q
I will rave all day long about Adam's remote tuning ability - he did my Bronco (AKC0/AHACA) with phenomenal results.
Adam, do I have the most recent strategy or should I update?
'92 Ford Bronco Prerunner
DART SHP 427w Stroker
TR-6060 6-Speed 4x4 conversion
FTI TF High Port CNC 230 Heads & FTI Custom Cam
Holley 95mm Hi Ram
FRPP 90mm DBW Throttle Body & Pedal
FRPP 60lb Injectors
SW 2"/3.5" High Port Long Tube Headers
Haltech Nexus R5 ECU/PDM
CNP Ignition
Old Motor & Trans: FRPP 302, E4OD, 80mm MAF, AKC0 EEC tuned by Core, E303, GT40X, Edelbrock EFI Truck etc
Holley 95mm Hi Ram
FRPP 60lb Injectors
CNP Ignition
Hmmmmm, I found the AHACA strat that is included with the Tweecer works just fine on my FLY1.
Users browsing this forum: No registered users and 148 guests
