Re: A9L2 base tune
dsftm is the minimum time you must be on the throttle in order for dfso to work
you can set it to 0 with no ill effects
NIKwithoutaC
Re: A9L2 base tune
Thanks man!decipha wrote:bad write, works now
Re: A9L2 base tune
lots of things going on in there no doubt. i tried it on one of my grudge cars. a9l forced ol e85 347 blower car with 2 stages of nitrous. and it didn't even want to idle. didn't give it much though as i was at the track, so i went back to my old tune. i will work on it some more this weekend and give it another try. maybe on a more stockish a9l set up.
91foxbodygt
Re: A9L2 base tune
Setting dsftm to zero got rid of all my decel popping. I can still hear a pop between the 1-2 shift sometimes though. I am going to download the new a9l2 bin and try it out as well.decipha wrote:dsftm is the minimum time you must be on the throttle in order for dfso to work
95 Cobra 408w, T56, 3.90s, 90mm LMAF & 39lb. injectors, J4J1 BE/QH
455hp/434TQ
91 GT 302w A9L2, GUFB, BE/QH
455hp/434TQ
Re: A9L2 base tune
You might as well have just disabled dfso all together.....91foxbodygt wrote:Setting dsftm to zero got rid of all my decel popping. I can still hear a pop between the 1-2 shift sometimes though. I am going to download the new a9l2 bin and try it out as well.decipha wrote:dsftm is the minimum time you must be on the throttle in order for dfso to work
mustangmitch
Re: A9L2 base tune
i have downloaded the a9l2 on my computer what programdoi need on my competer to open it thanks mustangmitch@charter.net
91foxbodygt
Re: A9L2 base tune
Binary Editormustangmitch wrote:i have downloaded the a9l2 on my computer what programdoi need on my competer to open it thanks mustangmitch@charter.net
455hp/434TQ
455hp/434TQ
Re: A9L2 base tune
installing A9L2 on my mild 347 tonight, gonna change cid, injector slopes, put in the MAF function I got from pro-m, and cross my fingers. runs pretty good on the stock tune, hoping for a smooth transition....
89 LX
A9L/GUFB, BE2012, LC-1
347 with RHS 180s, B303, 1.72rr, 9.5-1
Ford racing 30lb injectors, Walbro 255
75mm BBK throttle body, 75mm Pro-M,
- JoeFFR5294
Should DELTA have been changed
In my reviewing of the AL92, my tune, and the original stock AL9 I came across the DELTA "TPS Break point voltage" scaler. I noticed it was changed in the AL92 tune from stock. I further saw that the notes said to adjust this only if adjusting DELHYS "Dashpot TP" and DELRAT " ISC Ram Control TP".
Delta was changed from stock of .04 to .05 but, both the DELHYS and DELRAT remained at the stock values of .065. Is this a problem or are the differences in DELTA insignificant?
Factory Five Roadster, 302 B cam, Explorer intake, Thumper Perf heads, 70mm Accufab TB, 80mm MAF, 12" Cold air pipe w/ small bend, 42lb FRP inj, AL9 Tweecer R/T BE & EEC Analyzer Best ET 12.898 @108.4
YouTube Videos: http://www.youtube.com/user/joeembery#p/u
My Pics:
http://s207.photobucket.com/albums/b...cpZZ1QQtppZZ16
My Pics:
Re: A9L2 base tune
its negligible, not neccessary to change the other scalars
i changed it in the a9l2 because i've witnessed some 'noisy' tps cause surging at idle due to the ct/pt flags bouncing back and forth
fox bodies rule
Re: A9L2 base tune-long post, seriously
so here goes. I compared A9L2 to A9L and came up with the following comments, questions and observations. I have read all 7 pages of posts but the comparison is what tipped me over and triggered this
SHKCHG was .15, is now 2.2lbs what does this do exactly?
HCAMSW was enabled is now disabled, why and what does being in the "filtered air mass" mean?
PIPNUM even though DSFO is shut off, shouldn't the value be 1 to null PIPNUM out or is the change from 4 to 200 to slow the transition if PIPNUM is enabled for an automatic?
MFASW chased this PID all over and it is seems circular so do I assume that it doesn't exist in GUFB/eec IV? which then begs the question why is it enabled in stock A9L bin
ZHGSWI/FN071 settings seem to conflct with definitions at bottom of PID page, also seems preponderance of thinking is that it is a lean condition causing bucking at low rpm low load but the changes made skew the response to input to be lean rather than rich so is there a paradox here or is it becuase fn1360 is enabled and the transition settings don't apply, or?
CCDSW switch changes control to eec instead of TFI, but I'm going to assume that anyone injected is running a TFI if they still have the eec-IV so could you explain the change?
MILTMI setting cracks me up-does having a flashing MIL mean that things have really gone to hell in a hand basket as opposed to just aerating the oil pan?
MNPIP8 setting is changed to 25000 but everything else is shut down by 6500 in the tune because the fuel was shut off at 6500 rpm and turned back on at the same rpm, is this to keep the eec from trying to flip out because it can't process instructions to shut off and turn on fuel at the same time, also the new setting seems to conflict with the notes at the bottom of the PID pages that have "more than and less than" value notes related to (NLM_CL & NLM_SH) setting instructions, so could you explain?
SHKTP could you please explain what a "damper" is?
I am trying to understand the why behind the what, thanks!
'90 hatch, 363, TW 205 11R's, FTI cam, lightning MAF, RPMII, long tubes, QH, EA, BE ...
Re: A9L2 base tune
I downloaded this tune shortly after it was first posted. I put in my injector functions, TB airflow, idle rpm, engine size, MAF transfer and maybe a few other things. Basically adding my engine info. The car starts up and idles great but as soon as I begin to touch the throttle it begins to die. I assuming it needs some more fuel. What would be the best way to get fuel in on tip in? If it wasn't so cold I'd get out there and get the wideband hooked up again.
1937 Ford Coupe, 351C 4v, Comp cam HR224/232, T5, A9L, Lightning MAF, FMS 30lb injectors, with Qhorse and BE.
Re: A9L2 base tune
You may want to download A9L2 again. Decipha has updated it several times since he origianally posted it.351C4vEEC wrote:I downloaded this tune shortly after it was first posted. I put in my injector functions, TB airflow, idle rpm, engine size, MAF transfer and maybe a few other things. Basically adding my engine info. The car starts up and idles great but as soon as I begin to touch the throttle it begins to die. I assuming it needs some more fuel. What would be the best way to get fuel in on tip in? If it wasn't so cold I'd get out there and get the wideband hooked up again.
Re: A9L2 base tune
shkcg is used to calculate hard accel, its done for background calculations
hcamsw disables adaptives while rpm adders are active
pipnum enables time for fuel to stabilize before allows closed loop
mfasw is setup correctly so just flip the switch if you want it
fn071 is scaling for spark and a few others
zhgsw1 being reduced allows for an aged o2 or slight ground resistance to still control fuel correctly
ccdsw enables a ccd efi module to function correctly
if the CEL comes on you have an issue, could be ECT sensor which would cause cold start issues, or could be MAF which could cause a blown piston
mnpip forces fuel cut and failure management, by calibrating it out the rev limiter does its job
shktp is tied in with shkcg, its the minimum tp to allow hard accel calculation
- JoeFFR5294
Re: A9L2 base tune
Is the IDLRPM scaler supposed to be about 200+rpm from base idle settings? The stock bin settings are Idle in Neutral and in Drive 800rpm and the IDLRPM scaler is set at 1000 rpm. In the AL92 tune the Idle in Neutral 800 and in Drive 896rpm and the IDLRPM scaler is set at 850 rpm.
In my tune I have my base idles at 848 and adjusted the IDLRPM scaler is set at 1050 rpm and my idle doesn't fall off too quickly and stumble like it did before.
My Pics:
My Pics:
fox bodies rule
Re: A9L2 base tune
thank you for going through my list, the changes and definitions make alot more sense to me now
vortechblown306
Re: A9L2 base tune
Thanks for the tune!! It works great except when I'm taking off. It wants to die if i'm not giving it more than 14-1500rpms to take off but after that its hell on wheels. I put in my maf transfer and my injector high slope and low slope numbers (i got the high and low from 1 of your previous posts for fms 30's). I'm running 306 with 30lb injectors gt40 upper and lower 1" spacer, 70mm bbk throttle, 75mm mass air, fenderwell cold air, edlebrock performers, b303 cam, hooker headers, no cat bbk h, flowmaster 40's....
I havent logged anything or dyno'd it yet and I dont have my lm-1 hooked up but from the base tune i got from poweraddersolutions to this one, this one seems way better.
Thanks man some people just want $$$ to give information like this. Thanks for being straight up and helpful! It really does mean alot to people like me that know just a little bit that gets me by.
Re: A9L2 base tune
I would post up a datalog so Decipha can help you get that lil taking off glitch taken care of.
vortechblown306
Re: A9L2 base tune
If it would stop freakin snowing I'd like to get a good data log.EDS50 wrote:I would post up a datalog so Decipha can help you get that lil taking off glitch taken care of.
I have 3 mustangs so this one is my street car/ rice eater. I've also been working on my 393 stroker thats my lseater
Re: A9L2 base tune
Snow is no excuse. Drove mine in the snow and ice today.....yeah it sucked....vortechblown306 wrote:If it would stop freakin snowing I'd like to get a good data log.EDS50 wrote:I would post up a datalog so Decipha can help you get that lil taking off glitch taken care of.Before I do I think I'm going to change the maf transfer back to the original A9L2 and see what that does. If it doesnt solve the problem I'm going to change back to my maf curve and post a log.
I have 3 mustangs so this one is my street car/ rice eater. I've also been working on my 393 stroker thats my lseaterand I want to get those 2 mustangs in the barn so I can start sanding on my 64 1/2 to finally start painting it. Too many projects and not enough time.
Users browsing this forum: No registered users and 90 guests
