Foxfan88
"EA has stopped working" when loading EA in vista...
Post by Foxfan88 » Sun Jun 08, 2008 5:32 pm
lately i have been getting an error when booting up EA, i am using vista and half the time it will give me the error and tell me windows will let me know if a solution is found, usually i close it out and boot it up again, sometimes it works the 2nd time. just have to keep rebooting the program until it works. its a game of chance lol
is there a fix for this?
Brett
91 mustang gt 5.0 c4 auto
a9p ECU running GUFB strategy
TFS twisted wedge heads, f-cam, typhoon intake.
Moates QH using BE/EA
70mm single turbo setup.
86GT
BE/EA Developer
Re: "EA has stopped working" when loading EA in vista...
Post by 86GT » Wed Jun 11, 2008 12:37 pm
Make sure that in vista that you turn off the UAC (User Access Control)
Danknugz302
Post by Danknugz302 » Mon Jul 14, 2008 3:49 pm
I had the same problem, turning off UAC didn't help either
88 GT t-top windsor jrs,f303, Edelbrock RPMII,s-trim, tko600, 3.73s
86GT
BE/EA Developer
Post by 86GT » Mon Jul 14, 2008 6:40 pm
Is there an error message?
It is kind of hard to fix something I can not re produce.
Danknugz302
Post by Danknugz302 » Sun Jul 27, 2008 10:39 pm
no error message, just says eec analyzer has stopped working, then windows tries searching for a solution and quickly says a problem caused the program to stop working correctly. windows will close the program and notify you if a solution is available. if it makes any difference I'm running Vista home premium 64 bit.
86GT
BE/EA Developer
Post by 86GT » Mon Jul 28, 2008 3:09 am
uninstall EA and then run the clean utility and then reinstall EA. If you need a coy of the clean utility shoot me an email.
Danknugz302
Post by Danknugz302 » Tue Jul 29, 2008 4:58 pm
still had the same problem after uninstalling, deleting its folder from the programs x86 directory, then ran cuperutilities eraser and then re tried, still same problem, maybe that erase utility just sucks?? I dunno man, it helped me so much when I had my old laptop and XP its a shame I got this new one without it, I guess I'm just goin to end up hijacking either my mother or brother's laptop with xp and just using that to make it easier
86GT
BE/EA Developer
Post by 86GT » Tue Jul 29, 2008 5:14 pm
Danknugz302 wrote:still had the same problem after uninstalling, deleting its folder from the programs x86 directory, then ran cuperutilities eraser and then re tried, still same problem, maybe that erase utility just sucks?? I dunno man, it helped me so much when I had my old laptop and XP its a shame I got this new one without it, I guess I'm just goin to end up hijacking either my mother or brother's laptop with xp and just using that to make it easier
Wrong utility. Email me and I will send it to you.
n97343
Post by n97343 » Fri Mar 06, 2009 10:31 am
I have been toubleshooting this same problem on my laptop. Has a cure been found?
95 Mustang GT Convertible, AFR heads ,Ported Explorer upper and lower manifold.42# injectors , 90MM MAF,AEM Power pipe, Crane 2031 cam, Crane 1.7 RR, 9.2-1 compression ,Vortech Supercharger v2SQ ,12 psi boost, 4r70w transmission, Circle -d 3200 Stall Converter BBK Upper and lower Rear Controls Arms,3.27 gears,CBAZA,U4PO, Moates QH BE/EA , AEM WB. (CBAZA).
n97343
Post by n97343 » Fri Mar 06, 2009 3:09 pm
I uninstalled and ran the cleaner then re-installed, rebooted. EA is still stopped by windows. Is there anything else I might try. Thanks
n97343
Post by n97343 » Fri Mar 06, 2009 3:12 pm
I have a hp pavilion DV4 1225dx notebook, I uninstalled and ran the cleaner then re-installed, rebooted. EA is still stopped by windows. again . I must be missing something. But what?
86GT
BE/EA Developer
Post by 86GT » Fri Mar 06, 2009 3:12 pm
what version of dot net are you running. Make sure 3.5 is installed.
n97343
Post by n97343 » Fri Mar 06, 2009 3:44 pm
I have .net 3.5 sp1
Description
Stopped working
Problem signature
Problem Event Name: CLR20r3
Problem Signature 01: eec analyzer.exe
Problem Signature 02: 3.1.0.4
Problem Signature 03: 490fe5a5
Problem Signature 04: EEC Analyzer
Problem Signature 05: 3.1.0.4
Problem Signature 06: 490fe5a5
Problem Signature 07: 23
Problem Signature 08: e0
Problem Signature 09: System.InvalidOperationException
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 1033
I don't know if any of this will help .
Thanks for helping.
86GT
BE/EA Developer
Post by 86GT » Fri Mar 06, 2009 4:04 pm
Send me an email and maybe I can remotely log in and see what is going on.
86GT
BE/EA Developer
Post by 86GT » Fri Mar 06, 2009 4:16 pm
I just had someone tell me that EA will not work if it is installed in any other location than what the installer place it. Is yours installed in the default location? If not try it in the default location. I will have to test this.
