lm1 datalogging
i have been trying to datalog with an lm-1.i am not sure if i have the correct output on the lm-1 connected to pin 27.i have looked everywhere on this topic?which color wire is it?i connected the white wire to pin 27 & grnd to the eec ground.is that correct?i havent checked them with a voltmeter.also i can datalog from logworks but nothing in binary editor.i have the payload set to 2 and all my voltage settings for afr and tags to afr.should i just run a usb hub adaptor for the twEECer and lm-1 together?lm-1 keeps saying com failure.i know the twEECer is installed b/c i installed a injector template and did see afr change.i am a newbie and sure i have many more ??????????????????thanks for any input
91 GT 331 BOSS block,cnc'ed trickflow 205 heads & box-r intake,f-cam,76mm on3 turbo kit,mac 3in catback,granatelli k-member,dynamic c4 trans,fr500's wheels,3.73's,twEECer r/t with BE/EA. BUILT & TUNED BY ME
mustangless
Re: lm1 datalogging
If you have BE you can datalog with the serial port. I could never get my analog to work right, but to find it I plugged the analog directly into the egr harness.
1994 Mustang GT 4r70w U4P0
60mm Turbo .5bar Single 3" exhaust
3" pmas ati tube
42lb injectors
3" pmas ati tube
42lb injectors
Re: lm1 datalogging
I KNOW TO HOOK THE LM-1 TO THE EGR CIRCUIT.BUT WHICH ANALOG WIRE?LM-1 LOGS THROUGH LOGWORKS BUT NOT IN BE.WHATS THE DEAL
mustangless
Re: lm1 datalogging
It does not matter which analog wire you use. You just have to know the one you used so you can program it with lmprogrammer.
You can't log with logworks and BE at the same time. Have you checked the box under BE? I have an older version of BE, but it does not come up in the log as AFR. Its all the way on the right side as lc102.
3" pmas ati tube
42lb injectors
3" pmas ati tube
42lb injectors
Re: lm1 datalogging
the boxed is checked.now what about configure settings.i have channel 1 tagged as afr and the edit label checked for 5 volt.is this correct?
mustangless
Re: lm1 datalogging
leave it on afr, not 5 volt. You should not be able to do anything to the CH1 box.TROYR615 wrote:the boxed is checked.now what about configure settings.i have channel 1 tagged as afr and the edit label checked for 5 volt.is this correct?
3" pmas ati tube
42lb injectors
3" pmas ati tube
42lb injectors
Re: lm1 datalogging
ok got afr reading in the channel box.but still cant datalog.in calcon or tweecer.can run logworks to check afr.thats ok.
