avbronco
No datalogging on B/E
Post by avbronco » Sat Jun 05, 2010 5:41 pm
Ive got my Q/H back and new A9L, loaded up all the tune slots but cannot get my stuff to datalog. Ive checked the boxes I want to datalog(8 of em) and have it on 8 bank tune 2 but even the analog dash is at zero. anybody know what Im doing wrong?
1968 Bronco Sport 427 windsor,f/i
A9L 42lbs inj. ported Victor efi
75mm t/b 80mm pmas maf, calabrated for 42s.
Q/H -B/E-E/A AEM wideband
Re: No datalogging on B/E
Post by decipha » Sat Jun 05, 2010 6:17 pm
why would you only datalog 8 payloads??? :confused: ???
:confused: ??
log them all except "N_byte" which is for the tweecer :roll:
make sure you plug the usb cable in AFTER the ignition is on
let the green indicator illuminate at the lower right of BE and go to payloads,
select all except for N_byte and on the right side save the payload as 'all'
then go to digital dash and click start, once it starts polling fire she up
avbronco
Post by avbronco » Sat Jun 05, 2010 6:20 pm
Going to try that now, stay tuned....
avbronco
Post by avbronco » Sat Jun 05, 2010 6:38 pm
Works like a charm.
avbronco
Post by avbronco » Sat Jun 05, 2010 9:16 pm
Ok, now that I got the digital dashboard to work, and hit start it is showing everything, problem is it isnt saving it in datalog files. It shows 1kb and time but nothing is on excel, now what am I doing wrong?
Post by cgrey8 » Sun Jun 06, 2010 4:53 am
Is the enable datalogging checkbox selected?
avbronco
Post by avbronco » Sun Jun 06, 2010 3:58 pm
Yes, I read somewhere that sometimes you have to uncheck and check the box again, I will try that next.
avbronco
Post by avbronco » Sun Jun 06, 2010 5:04 pm
Ok, tried everything but still no datalog. It shows 1kb in be datalogs and the excell screen is there but nothing? also there is no tach on the digatal dashboard.
junior73
Post by junior73 » Mon Jun 07, 2010 1:29 pm
I had the same issue. I had inadvertently enabled the Datalog Auto Start with a Tag of "None", which could never be reached, so the logs were never being created. ONce it was unchecked, it worked like a champ.
302; Thumper Heads; TFS 1Cam; Cobra Intake; Vortech V3SQ; UPR Boost Pipe; 42lb injectors; 255lph fuel pump; Lightning 90mm MAF; MAC shorties; Off-road H pipe;A9L; QuarterHorse; BE; LC-1 Wideband
avbronco
Post by avbronco » Mon Jun 07, 2010 6:46 pm
That was the problem :biggrin: now im a datalogging fool!!!
junior73
Post by junior73 » Fri Jun 11, 2010 3:45 pm
avbronco wrote:That was the problem :biggrin: now im a datalogging fool!!!
8) Glad it worked for ya!
Users browsing this forum: Bing [Bot] and 35 guests
