What motor is everyone running?
302 stoker
3
30%
302 stoker
3
30%
351W stroker
2
20%
351W stroker
2
20%
Big block stroker
0
No votes
Big block stroker
0
No votes
SOHC 4.6
0
No votes
SOHC 4.6
0
No votes
DOHC 4.6
0
No votes
DOHC 4.6
0
No votes
Big block stroker
0
No votes
Big block stroker
0
No votes
Other pushrod
0
No votes
Other pushrod
0
No votes
SOHC 4.6
0
No votes
SOHC 4.6
0
No votes
DOHC 4.6
0
No votes
DOHC 4.6
0
No votes
Total votes: 10
Cobra Steve
What motor is everyone running/planning on running?
Post by Cobra Steve » Thu Oct 16, 2003 7:53 pm
Thought this might be fun. :D
I have stock 302 now, 357 on the stand.
Ghudnub
Post by Ghudnub » Thu Oct 16, 2003 8:03 pm
347 Will be back from balancing/honing end of next week! I need to pick a new cam... :?
'95 GTS lives on in '00 V6 body! 347, J4J1, LPT, 6037's w/Comp Beehives, Extrude honed Cobra, 75mm TB, 87mm Pro-M, TFS Stage 2, 1.7's, 30#r's, LT's, Offroad X-pipe, Bassani catback, and every suspension tweak except for a torque arm.
Ghudnub
Post by Ghudnub » Thu Oct 16, 2003 8:05 pm
Hey, half of those who have responded are going my way! I must be doing something right. :lol:
Greg
TexasDevilDog
Post by TexasDevilDog » Thu Oct 16, 2003 8:51 pm
Currently 281 DOHC, plan turbo 281 DOHC
Richard
2001 Performance Red Cobra MSE3
Oil pump failed Oct 2003
Houston Performance all forged .020" over 9.1:1 CR short block - PnP heads with FR500 camshaft kit
Adding a pair of hair driers some time
StangQuest
Re: What motor is everyone running/planning on running?
Post by StangQuest » Thu Oct 16, 2003 11:32 pm
Cobra Steve wrote:Thought this might be fun. :D
My 357 just got put together :wink: Can't wait to drop it in :D :D :D
1995 Rio Red GTS
P600B w/3-core IC, Edelbrock Performer heads, RPM intake, Crane 2030 Cam,.....ect
FastRat
Post by FastRat » Fri Oct 17, 2003 2:47 am
Im runing 88 302 with DA1, ported stock heads, 3.73 gears an SROD.
This in my 85LX
I working on 351w stocker for it, I thinking 393, but not rule 408.
I hope have the engine to a shop for the work next week.
Right now I thinking 393 with 11:1, like roller cam,( bit clostly as I have flat tappit cam block) Not sure how big cam I like run yet, mostly looking for good mid rage power, as this steet car. I thinking long tube headers, I need new header so figger go with long tube, As for heads I not sure have $$ for good ones so, thinking about adding bigger valves and porting the stock E5 351w heads. I very up air on intake like heads I thinking to keep cost down, I thought about reworking a carb intake for injetion.
I had few tail me they think 11:1 to much, had more said it fine with good gas. I been playing with TwEECer for bit, think I tune the mix and timing so I thinking it sould ok.
I can't wait get this engine going but want keep it real so not run out $$ 1/2 though.
Mike L :ukliam:
Cobra Steve
Post by Cobra Steve » Fri Oct 17, 2003 4:55 am
I bought my cam at Bennett Racing. It was only $290 or so shipped for a custom grind reduced base circle. I'm tapping the block for the spiders this weekend, just watch the cam bearings, as if you drill to deep, you get into those. My motor I'm building right now is for nitrous, so it is 10.7:1. As long as you run 93 octane, aluminum heads, and be carefull, it is fine.
As far as 351 strokers, I plan on de-stroking my turbo motor. It should end up around a 337-340 cid, 8.5:1. A destroked 351W has lots of ring land and can turn some serious Rs.....add a T-76, custom sheetmetal intake/water-air intercooler, and you have lots of power. :D
93Cobra#2771
Post by 93Cobra#2771 » Fri Oct 17, 2003 10:22 am
Running the stock block 302 with the mods in the sig. If it ever goes, 302 stroker here I come (like keeping the stock hood).
Richard White
X3Z, RT, GT40y's, ported intakes, Steeda #18, AFM PP, 80mm Pro-M, MSD, MAC E/L, Dr Gas X, 3.73, etc.
I do Reproduction Mustang Window Stickers!
"Tweecer Defs" http://autos.groups.yahoo.com/group/twe ... mentation/
5150lx
Post by 5150lx » Fri Oct 17, 2003 12:13 pm
Dart 8.2 Block .030 over
Scat 331 rotating assembly
TFS heads/intake
and a lil Novi 1000 :D
Dale McPeters
Professional Tuner/Shop Owner
Post by Dale McPeters » Fri Oct 17, 2003 1:53 pm
All sold but the ones below.
'68 torino gt 390ci w/c-6 trans (needs to be finished)
'03 Mach 1 281ci 32v
Last edited by Dale McPeters on Mon Oct 27, 2003 5:42 pm, edited 4 times in total.
Dale McPeters
Post by Dale McPeters » Fri Oct 17, 2003 2:00 pm
Ghudnub wrote:Hey, half of those who have responded are going my way! I must be doing something right. :lol:
Greg
Greg, the 347 will make you a very potent engine when setup right, I know that I like mine.
Dale
FastRat
Post by FastRat » Sat Oct 18, 2003 3:17 pm
Im trying stuf my 351w stoker under the stock hood, sure be fun.
I looking at running carb intake rework for injetion, I plan running a carb like air leaner, as Im running SD so I not have MAF to pipe in. thought about painting 5.0L on the air cleaner, as my car is 85 LX it would been carb, maybe it past as stocker :twisted:
Mike L :beers:
boss96
Post by boss96 » Mon Oct 20, 2003 9:36 am
I've got a 96 GT, 4.6 mod motor. It has forged rods/pistons, cobra crank. ported PI heads with Modmax oversize valves, custom cams with .550lift/228dur@.050, MAC longtubes, Bullitt intake, vortech S trim with 2.87" pullie, 42lb injectors, ProM meter, Aeromtive fuel pump with Steeda fuel rails, etc. At the dyno it looks like it was heading towards 550rwhp on a mustang dyno until it broke but I'll be fixing that soon :cry:
Bob
Dale McPeters
Post by Dale McPeters » Mon Oct 27, 2003 4:46 pm
boss96 wrote:I've got a 96 GT, 4.6 mod motor. It has forged rods/pistons, cobra crank. ported PI heads with Modmax oversize valves, custom cams with .550lift/228dur@.050, MAC longtubes, Bullitt intake, vortech S trim with 2.87" pullie, 42lb injectors, ProM meter, Aeromtive fuel pump with Steeda fuel rails, etc. At the dyno it looks like it was heading towards 550rwhp on a mustang dyno until it broke but I'll be fixing that soon :cry:
Bob
Bob,
What broke?
Dale
408Stang
Post by 408Stang » Mon Oct 27, 2003 11:08 pm
I am running almost a full second faster with my 408 N/A vs my blown 306. The blower was fun for a daily driver, but it is nice to just whromp on the Stroker and not have to worry about things as much.
Clint
boss96
Post by boss96 » Tue Oct 28, 2003 7:54 am
Dale, I melted no. 8 piston (spark plug electrode was smashed). I was watching my wideband meter, was thinking to myself that it was running a little too lean (12.5-1), saw it head towards 13-1 and just as I was about to let off the gas it spit oil out the breather, hit the headers and caught fire :shock:
Some little piece of metal came out the tailpipe too.
Anyway, the motor still turned over, put a new sparkplug in but of course the damage was done, lots of oil buring.
It looked like the engine had some blowby during the runs too, so maybe it was oil induced detonation that took it out, not so much lack of fuel.
Bob
Dale McPeters
Post by Dale McPeters » Tue Oct 28, 2003 11:13 am
boss96 wrote:Dale, I melted no. 8 piston (spark plug electrode was smashed). I was watching my wideband meter, was thinking to myself that it was running a little too lean (12.5-1), saw it head towards 13-1 and just as I was about to let off the gas it spit oil out the breather, hit the headers and caught fire :shock:
Bob
Bob, That is not good. :( How much boost were you running? Hope it did not burn up much under the hood. How much damge did it do interanally or do you know yet?
I have finally found the rods & pistons that I want to put in the '03 Mah 1. I got a call from Jim at ATI (Prochargers) Friday & they have finally came out with a kit to keep the shaker functional. :D I was origianlly going to do turbos, but after doing some research I think I am going to go with the ATI setup, because of heat related stuff & keeping it streetable. I just hope what happened to your engine does not happen to mine. They send a chip with the kit so maybe that will give me a baseline to start with. I am going to try to run 10-12 lbs if everything goes right :roll:
Keep us informed on how it turns out. I am interested to see if it hurt the block or not.
Dale
boss96
Post by boss96 » Tue Oct 28, 2003 6:19 pm
Dale, there was no fire damage to speak of, it just caught fire on the headers from the oil and we put it out quickly.
I'm running a 2.87" pullie on the vortech so that works out to about 15lbs at 6krpm and it could go a little higher at 6500.
I started taking the engine apart tonight but won't know much until I get the motor out of the car. I am expecting some kind of damage to the head since a piece of metal flew out the tailpipe, maybe a damaged valve. The block does not have a hole in it so the only thing will be whether or not the bore is scored too much that going .030 will not clean up. It is already bored .020 so we will have to see and of course I will need new pistons if it can be bored out.
I can get a used block cheap though if I need to so either way it should work out.
What rods and pistons are you getting? There are quite a few manufacturers out there so there should be no problem.
The ATI should be pretty nice, tuning it should not be that hard, just pull timing at high load and give it enough fuel.
Bob
Dale McPeters
Post by Dale McPeters » Wed Oct 29, 2003 2:13 pm
Bob, Good deal on the fire damage, I thought it might have gotten more of the under hood stuff. I hope that it did not get the block.
I think I am going to go with the manley Pro I-beam rods, supposed to be good for 800hp @ 7500? And JE or ModMax forged pistons with at least a 17cc dish, probably will be the JE though. There is a guy that lives close by that is running a Pro Turbo Kits turbo on an '03 Mach 1 with stock rods & pistons but I do not think that I want to try to put any boost on mine until I get the junky rods & pistons changed out in mine. I just want a little more insurance.
I think the ATI should be fairly easy to tune, but I will need to do something about the fuel system as I would like to run 10-12 lbs of boost min. Mike Glover is supposed to send me a new file for the '03 Mach 1 to test (datalogging etc.? do not know yet). I have a "ccf" file now but some of the spark tables etc. are skewed or something, does not display correctly. I have sold the 91lx & 93gt so that should give me plenty of green to get the Mach 1 setup the way I want it, maybe after the first of the year before it is finished as Thanksgiving & Christmas are just around the corner. Family stuff you know.
Let me know how the engine turns out.
Dale
ERStettin
Post by ERStettin » Sat Nov 01, 2003 11:18 am
347 combo here as well. Another vote for stroker 302
Stengun
Post by Stengun » Mon Apr 08, 2013 2:41 pm
Howdy,
Stroker 351W.
414CID
Probe bottom end. AFR 205 heads w/ Harland shaft mounted rockers. Edelbrock Vic Jr intake modified for port injection w/ Mass-Flo 4V style TB. AFM N-71 cam and lifters. Coil pack ignition w/ MSD cam sync plug and CDAN4/CZH3 EEV-V w/ a slot MAF sensor.
Paul
Post by cgrey8 » Mon Apr 08, 2013 5:37 pm
It looks like there's some kind of bug in the forum's ability to host a poll. I've tried to edit out the duplicate entries and all it did was make a bigger mess.
Post by decipha » Mon Apr 08, 2013 7:08 pm
im sure 10 years ago its was operating on a different php
Post by EDS50 » Tue Apr 09, 2013 12:14 pm
Talking about digging up an old thread.... :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 124 guests
