Adam Marrer @ Pops Racing- Tuning Genius
Its pretty well known that tuning the 94-95 can be difficult. I have spent the last 2 years trying to get mine right. I started with a local, well known/respected, mustang performance shop and had a tune (SCT) that made decent power, but the driveability was absolute SHIT. Fishing idle, extremely slow drop in RPM's when coming down, hot start issues and the list goes on. I then bought a Moates QH and tried to tune the car myself. I soon realized i dont have the time to learn.
So i contacted Adam Marrer with Pops Racing in New York. To say the least i was skeptical that someone could tune my car from afar given that my local guy, who has had several write ups in MMFF & 5.0, couldnt seem to get my car tuned correctly.
Adam FAR exceeded my expectations. He not only got my car tuned to perfection, but really went out of his way to help me get the end result i wanted. If anyone is having trouble tuning their car, i STRONGLY suggest you get in touch with Adam. His prices are reasonable, hes pleasant to deal with, and his expertise is something to be admired.
Jason
Jason
95 GT- Stock bottom 302, AFR 185 heads, Trick Flow Intake, Comp Cam, Long tubes, 76MM MAF, 30lb injectors, 75MM TB, MSD Dizzy and 6al, No smog,Magnaflow Cat back and lots of suspension goodies!!!
Re: Adam Marrer @ Pops Racing- Tuning Genius
Great to hear. I've had great dealings with Adam as well though I haven't gotten tuning help, just a strategy. Be sure to take the time to see what he changed from your previous tune. Call it "accelerated learning." ;-)
Quarterhorse Tuned
FBFG2 Strat(Thanks popsracing.com), PTP2 EEC
04 Mustang GT, Paxton Novi 1000 w/supporting mods
that is also one of the good things about working with someone like him. I got to see everything he did..really helped me grasp BE and how to use it correctly..
hes a pretty wise gent, a personal friend as well
when i first started tuning fords he gave me some much needed direction and sound advice "expertise", he's always steered me right even in my rebellious state lol, none the less a huge contributor to the diy tuning community
now post a dyno sheet, I'll guess by your sig that she's got to be making around 335 or so?
I believe it was right at 352 crank...just over 300 to the wheels..i...i think my heads are too big...with the 165's i would probably pick up more HP..decipha wrote:hes a pretty wise gent, a personal friend as well
thats a misconception, don't let the heads limit you, let the cam, you might sacrifice a bit of low end torque but its worth it for the gains on the big end
POPSRACING
Thanks for the complement, I'm just trying do my job.
Land and Sea chassis dyno
1995 Cobra, 408, sold...
Awesome!!!!
1993 Mustang LX Reef Blue
I had no idea that a remote tune could be as effective as a Dyno tune - I just got off the phone with Adam, and I'm going to try and do my tune remotely. Much easier then coordinating a time to meet in a city hundreds of miles away from both of us.
'92 Ford Bronco Prerunner
DART SHP 427w Stroker
TR-6060 6-Speed 4x4 conversion
FTI TF High Port CNC 230 Heads & FTI Custom Cam
Holley 95mm Hi Ram
FRPP 90mm DBW Throttle Body & Pedal
FRPP 60lb Injectors
SW 2"/3.5" High Port Long Tube Headers
Haltech Nexus R5 ECU/PDM
CNP Ignition
Old Motor & Trans: FRPP 302, E4OD, 80mm MAF, AKC0 EEC tuned by Core, E303, GT40X, Edelbrock EFI Truck etc
Holley 95mm Hi Ram
FRPP 60lb Injectors
CNP Ignition
a dyno is nothing more than a tool to get you in the ballpark
real tuning is done at the track
ADAM IS A TUNING GENIUS!
Adam just recently did my (remote) tune, and to summarize my experience, I will simply repeat and reaffirm the original poster (Jason's) statement. I'm a technically proficient guy in many areas (other than EFI tuning) and so it was instantly apparent how incredibly fluent he is in regards to tuning, and how rich his experience and knowledge-base is as well.
Adam was also incredibly courteous, patient and generous with his knowledge throughout the process, and it was a pleasure dealing with him.
And on top of that, my truck now ROCKS. It's faster, smoother, shifts 100% better and all of the quirks are gone. Can it get any better? Adam, thank you very much!
S
S
Holley 95mm Hi Ram
FRPP 60lb Injectors
CNP Ignition
Holley 95mm Hi Ram
FRPP 60lb Injectors
CNP Ignition
dualdj1
Love seeing/hearing success stories like this!
1978 Mustang II King Cobra
5 spd Manual
5 spd Manual
My turn will come soon....hopefully with the same results as you guys have had.
schmetty89
After reading this seems like i might be going with adam as well i can build a monsterous engine no question but tuning efi is a nightmare to me i always had a friend do it then he would sit in the car with his laptop realtime datalog and tuning while i drove until it was perfect.
Id love to sit on a dyno all day JK and this sounds far easier.
1994 Mustang GT Vert 5.0 5 speed (base car)
Tuned with Moates QH using Binary editor and EEC Analyzer
Wide Band Innovate MTX Series
EEC IV (CBAZA strategy) (T4M0 calibration)
FRPP 306 crate engine
E303 Cam
GT40x Head 1.6 ratio rockers
9.1 compression
BBK Equal Length Ceramic Coated Shorty Headers
Stock H-pipe at the moment
Mac Performance 2.5" Pro Dump Exhaust
BBK SSI Intake
BBK Fuel Rails and FPR
BBK 75MM Throttle Body
Accel 36lbs/hr injectors
75mm Pro-M Mass Air Meter for 36Lb Injectors
E303 Cam
9.1 compression
BBK SSI Intake
