A9L2 base tune
it has occured to me that the vast majority of folks here utilize GUF ecus thus i felt compelled to do my part and aid in helping thy fellow enthusiast out by contributing my base A9L calibration i use on vehicles i tune, I have labelled it A9L2 to distinguish between it and a stock A9L
this 'base' tune is ideal for basically anything from stock to turbo nitrous engines
if anyone has any questions feel free to ask
http://info.efidynotuning.com/a9l2.htm
enjoy
here a link to the cbaza base tune for reference
viewtopic.php?t=19964
enjoy
Re: Convert SCT to bin. for BE
This reply was moved from a different thread:decipha wrote:fastsvo wrote:Decipha,decipha wrote:heres your professional sct dyno tune
my previous assumption was correct, its junk, i would never let a vehicle drive away like that
good luck
What makes it junk? What are you seeing or looking for in a tune to determine its worth?
first off your beginning with junk (stock foxbody tune is junk) so all the key areas need to be hit, fuel was never dialed in on the tune as its practically impossible the way they have it setup, all the 'tweaks' can be done regardless so any 'professional' dyno tuner should have a 'base' tune for more popular calibrations to start from. If you look in my sig i posted up my stock a9l2 calibration that i use for all my foxbody tunes, compare that to a stock a9l and you will see all the key areas the so called 'tuner' neglected to 'adjust'
I have a few questions for you regarding your a9l2 tune:
1. Why is ccdsw enabled
2. Why is edfhp enabled
3. Why is fn331b multipliers set to all 1.0
4. why is fn879 zeroed out
5. why is fn826a zeroed out
I am just wondering for my own educational purposes.
Re: A9L2 base tune
Much appreciated kemosabe. Should be fun to see how far off I am lol.
Scott
Scott
Re: A9L2 base tune
May the gods be with you sir.May your knowledge extend to the Nefarious species(thy women) when necessary.May you tune them to your desires.
Commuter 1990 LX: 306 Roller block,TW-170's, Ported Cobra lower,Slot sensor,BBK 65mm tb,19lb series III,stock airbox,K&N,0 Egr,155lph pump,speed density cam,1.6 7/16 rockers,T-5,3:27 rear.
Re: A9L2 base tune
Just a suggestion, but one thing that might help newbs learn better is a list of the changes made with an annotation of why it was done.
I am looking forward to checking this out when I get home tonight.
1989 Mustang LX (former SC State Patrol)
408w with AFR 205 Renegade heads, Victor 5.8 EFI intake, Flowtech Induction (Ed Curtis) custom cam, 42lb/hr injectors, 05+ Slot style HPX MAF, 90mm Accufab throttle body, custom intake tract, BBK 1 3/4" LT headers, Moates QH, BE and EA, Innovate LC-1, Smog pump and EGR removed,PCV plumbed through ProVent 200 as a catch can, stock ignition, Stock A9L computer
Re: A9L2 base tune
most of the changes should be obvious, if you question something or want to know why post what it is
Re: A9L2 base tune
Sweet!
thanks decipha! Looking forward to comparing to stock a9l and figuring out what is changed and why.
1993 mustang. GUFB A9L. 302,GT-40s,Tfs1cam,cobra intake,70mm TB,1 5/8 bbk longtubes,O/R h-pipe, flowmasters,80mm pro-m, frpp 42lb injectors, vortech v2 s-trim at 10psi,UPR powerpipe,Moates QH, BE & EA, innovate mtx
Re: A9L2 base tune
i just looked over it and i see 2 mistakes , hego bias table supposed to be all 0s and prldsw is supposed to be 0 where perload=load/fn035, i have no idea why those are what they are but ill fix it later tonight, still at work
if you have a ccd tfi and ccd is disabled your dwell will be static at barely nothing, using with a non ccd tfi has no ill effects, kind of a better safe than sry
so when you decide you want the ecu to control the fan all u gotta do is plug it in
its not
dashpot decay isnt 0 its .0081 with a linear decay dashpot can be finely tuned in using only pre position
the startup adder is done by the isc multiplier table
its not
Re: A9L2 base tune
Got a few questions..
Is the spark narrowed down to just the sea level spark table? To start dialing in fuel,is the only I need to do is disable the fn1360?
Ps will your long tube header template still work with this bin having the load scaling?
Jay
Jay
Re: A9L2 base tune
yeah jay sealevel only
fn1360 is already enabled but that won't dial in fuel, you dial in fuel by either injector slopes or maf transfer
you dont need the header template with this calibration, nor any of the other templates other than maf and injectors, thats the beauty of it
Thanks Mike.decipha wrote:1. Why is ccdsw enabled
by nulling the accel enrichment multiplier your ae is exactly whats in the table, makes it easier to dial in
the startup adder is done by bzztmr, that way u can clear it out sooner if need be
I was under the assumption that turning on the fan hardware isnt enough. There is some wiring involved as well to make it functional.
I was afraid or concerned with the dashpot decay rate that she would idle hang for too long before coming down.
Re: A9L2 base tune
you do have to wire it up for the output to function
dashpot can be fine tuned in pre position i usually do something like
xxmaxxx .8
5000 .6
100 .15
0 .15
0 .15
0 .15
etc...
then you only have the .6 and .15 to adjust to get it perfect
xxmaxxx .8
5000 .6
100 .15
0 .15
0 .15
0 .15
etc...
Re: A9L2 base tune
Thanks deciphadecipha wrote:yeah jay sealevel only
fn1360 is already disabled ? but that won't dial in fuel, you dial in fuel by either injector slopes or maf transfer
So no changes needed between long & short tube headers and fn1360 is not patched to this bin correct?
Re: A9L2 base tune
no changes, fn1360 stabilized fuel table is patched in the bin for those whom want to use it but disabled
Re: A9L2 base tune
looking forward to trying this out, thanks decipha. i cant get my driveability right, I hope this helps.
92 coupe
302, afr's, tfs 1 cam, gt40 intake, S trim, 42lb injectors,longtubes,pmas velocity, tweecer, lc1
Re: A9L2 base tune
Nice man! ill be using this once i start my tune!
Re: A9L2 base tune
np, i do what i can to help out
dont hesitate to post back with any concerns
88mustanggt
Re: A9L2 base tune
why is Z_DFSW disabled but you still make changes to dfso values? are they just the changes you would make if you were to run it when enabled?
88 fox, 302, gt40 heads, intake, stock cam, long tubes, ati procharger 42lbs, 05 slot , infront of a viper t56
AL9, GUFB, QUARTERHOURSE. BE/EA
Re: A9L2 base tune
yeah that way its as simple as enabling the scalar if you want to enable it, she'll function correctly
Re: A9L2 base tune
This one topic of interest I always brought up to Chris. It is my belief that dfsw was always disabled by default in the a9l calibration. I believe Chris is the one that is kind enough to keep all the gufx strategies and calibrations up to date and refined and I "think" as time evolved from 2009 or so that the pid became enabled by default. I believe dfsw was disabled by default in the original Ford calibration in the a9l and a3m series but was enabled by default in the x3z calibration. So in my oppinion Mike is correct in leaving it disabled by default in the a9l calibration. The only thing I would have Mike add is fn374 multiplier values should all be set to zero if enabling z_dfso or dfso as we know it per the comments on fn374.88mustanggt wrote:why is Z_DFSW disabled but you still make changes to dfso values? are they just the changes you would make if you were to run it when enabled?
Re: A9L2 base tune
I think the "enable/disable" scalar always had it enabled in the A9L BIN. I certainly didn't change that scalar and then upload my altered versions of that BIN. Although just because DFSO is enabled doesn't mean it actually worked. Other scalar settings were actually preventing it from working even though the feature was technically "enabled". So explicitly disabling it doesn't mean much since it never was really active to start with.
As for whether to use DFSO or not is a completely different discussion...one that's been discussed before and it's 100% personal preference. There's not strong argument to or not to use it. I use it, but others prefer to keep the fuel pumping to avoid excessive engine-braking.
Re: A9L2 base tune
Subscribing.
I have started with decipha's base tune A9L2, plugged in my MAF table today and was able to get a good data log and some decent idle/run time. Running @ 8.9 AFR and then runs 16 to 22 AFR on decel. Needs some personal tweaking, but it is a decent start.
91 Mustang GT vert 5.0L
A9P but w/ A9L2/GUFB- 5 speed 3550, Edelbrock Performer intake, ported, GTx306 heads, XE270HR cam, 1.6 Roller rockers, Pro-m 80mm- stock calibration, 70mm Accufab, longtube headers, Powerdyne supercharger- 7psi max, 19lb injectors, stock fuel regulator, 255lph pump, 3.73, EGR deleted, thermactor removed, still has A/C & power steering. Electric fan, 160 degree thermostat, timing set at stock, MSD distributor, 1 range cooler spark plug gapped to .035, MTXL-1, Moates, BE 2012, EA.
Re: A9L2 base tune
damn jon, your maf must be wayyy off
the only time i really use decel fuel shut off is on turbo engines with screwed up bov's or maf placement, or if someone wants it
the biggest problem with dfso is with automatics, if you bust through the traps and as soon as you come off the throttle the back wheels lock up (had it happen) its pretty hard to prevent it from getting loose, i don't use dfso on any automatics with decent power just not safe, at least not with the minimal control the guf ecu's give you over dfso
timinoakton
Re: A9L2 base tune
Sorry to fixate on the fan, but are all EEC-IV CPUs wired to control fans (i.e. to they have a relay/MOSFET populated on the cct board)? I thought I'd read that it was not this way, so I wired an external thermostat switch to control my fan and was PO'd as it is a natural thing for the computer to control.
Is adding a pin to the computer connector all that's required to get an actionable computer output for fan control? If so - bugger. I'll be adding to the wiring looms then....
Thanks - I'm going to port my current tune to the decipha A9L2 and see how it behaves.
cheers-
timm
cheers-
timm
FFR Roadster - SBF from 1990donor, TFS-1 cam, GT40 heads, exploder intake & TB, 70mm TB, most everything ported/polished, cone filter, dieted wiring harness, Quarterhorse....
Re: A9L2 base tune
supposedly some ecu's have the hardware whilst others don't, every ecu i've ever tried it on worked
Re: A9L2 base tune
You may already know,but you will need to wire it with a relay. Hooking the ground to pin 41 can damage the computer. The computer will not support enough current to run a fan with out a relay.timinoakton wrote:Sorry to fixate on the fan, but are all EEC-IV CPUs wired to control fans (i.e. to they have a relay/MOSFET populated on the cct board)? I thought I'd read that it was not this way, so I wired an external thermostat switch to control my fan and was PO'd as it is a natural thing for the computer to control.
cheers-
timm
http://oldfuelinjection.com/files/A9L_E-Fan_How-to.pdf
Re: A9L2 base tune
Correct. I am glad you posted this as just enabling the fan hardware in the tune is not enough. Its alot more involved with the fox ecm's.Crock wrote:You may already know,but you will need to wire it with a relay. Hooking the ground to pin 41 can damage the computer. The computer will not support enough current to run a fan with out a relay.timinoakton wrote:Sorry to fixate on the fan, but are all EEC-IV CPUs wired to control fans (i.e. to they have a relay/MOSFET populated on the cct board)? I thought I'd read that it was not this way, so I wired an external thermostat switch to control my fan and was PO'd as it is a natural thing for the computer to control.
cheers-
timm
Re: A9L2 base tune
a lot more involved? such as what?
how exactly does one expect to power a fan without wiring?
Re: A9L2 base tune
Well you elude to the fact that the a9l can control a e-fan as is. Thats not the case. The ecm needs to be pinned properly, the correct relays need to be used, a secondary temp probe for the fans need to be installed in the water neck or lower intake manifold for on off temps and a stock 80 amp alternator will not cut it with any old electric fan. A 130 amp 3g alternator is required if you dont want to melt your wires and tax your electical charging system and such. You will also need to instal and wire an a/c relay which would power the fans when the a/c is on turned on regardless of temp. That all sounds pretty involved to me if you want it done and operating correctly. Most will say the hell with the ecm controllint the fan and just power it to a key on source and a toggle switch if for anything out of shear laziness....lol...decipha wrote:a lot more involved? such as what?
Users browsing this forum: No registered users and 81 guests
