copcar
Help with a Pro-M 77 MAF transfer function
Post by copcar » Fri Jun 01, 2012 8:23 pm
Model: 77mm
S/N: 004785 (the 5 could be a 3 or an 8)
Calibration: CON30 (not quite sure about the N)
It is set up for a cobra processor and 30 lb injectors... I think.
Any help is greatly appreciated.
93 SSP, 3100 lbs. 302, B303/1.7, ported gt40 irons, stock valves. modified cobra upper (larger plenum extrude honed and knife edged) ported lower, frpp maf/30# inj. 3.90 gear. 12.37@109.78 on old Nitto 555 dr's. DA1250. untuned. No tuned track data.
Re: Help with a Pro-M 77 MAF transfer function
Post by decipha » Sat Jun 02, 2012 12:50 am
a stock meter is not calibrated, why not just make your own transfer? check out deciphas 2nd law of dialing in a maf
copcar
Post by copcar » Sun Jun 03, 2012 11:23 am
I am trying to put a tune together for a family members car that is a couple of hours away and I will not have the time to sort it out fully as there is no dyno. Just needing a good base to start with.
Post by decipha » Sun Jun 03, 2012 3:51 pm
y u need a dyno?
can't she/he shoot you back a log?
copcar
Post by copcar » Sun Jun 03, 2012 6:48 pm
no, don't need a dyno, but it would make the limited time I'll have with this car easier. Also, I am setting up a base tune to get started as I am buying him a Tweecer for Father's day. No datalog because no tuning apparatus has been installed yet. Once I've set the car up with a base tune he will begin his fun with tuning.
Post by decipha » Sun Jun 03, 2012 9:13 pm
why would you buy him a junk ass tweecer?
copcar
Post by copcar » Sun Jun 03, 2012 11:00 pm
Cheap and easy. I'm running it and we can discuss tunes using the magic of the internet.
Post by decipha » Mon Jun 04, 2012 1:13 am
correct you are, i suppose thats cheaper than buying a qh/be but its not worth it imo, you can do so much more with the BE definition file and the qh
copcar
Post by copcar » Mon Jun 04, 2012 7:59 pm
meh, not very sophisticated combinations. easy to tune. The car runs great as it is. This will give him something fun to do/learn.
Post by decipha » Mon Jun 04, 2012 8:05 pm
strippers are fun to do/learn as well and the cheaper one probably isnt going to do what the more expensive and newer one will
same applies
copcar
Post by copcar » Mon Jun 04, 2012 9:59 pm
True enough but I'm rather familiar with this old skank and although she may be a little rough around the edges, long in the tooth and have a few bugs all the important parts still work just fine.
Post by decipha » Mon Jun 04, 2012 10:01 pm
well when she doesn't put out anymore don't say i didn't forewarn you
copcar
Post by copcar » Mon Jun 04, 2012 10:12 pm
I'm still waiting on a properly good stand alone to pop out. Any ideas? 8)
Post by decipha » Wed Jun 06, 2012 1:07 am
its time consuming but its getting there, kinda on hold right now as i got other stuff going on
Users browsing this forum: Bing [Bot] and 118 guests
