rzfiveoh
dataloging??
Post by rzfiveoh » Wed Aug 08, 2012 3:12 pm
i followed all theses steps
"first open up BE
up top click on open then go to strategy, open your strategy
then click on open again and open your current tune
then go to the datalogging tab up top between 'tuner' and 'dashboard #1'
if you have a QH put a check in every single payload on the left hand side except n_byte, be sure you scroll down and select them all
on the right hand side there's a blue disc icon, when you pause the mouse over it says 'save payload' click it and name it ALL
right below that put a check in the box next to enable
then click the 'location' button and be sure you remember where you save it, this is where your datalogs will be saved to
now click on 'dashboard #1' and plug the USB cable in for the QH
wait 5 seconds for the QH to initiate and then once the green led is illuminated at the bottom right wait another 5 seconds then click the green arrow that says 'start' either up top or to the bottom right of the dashboard
no pics this is pretty straight forward
if you don't know what strategy your ecu uses you can search by typing in your catch code, if that returns 0 results post a thread about it and some one will chime in"
exept the "n_byte" could not find it.. everything seemed ok exept the rpm stayed on 0 the whole time.. also whe i treid to open the log it did not let me.. it said the filters removed all rows i have no filters enabled.. i tried diffrent logs none open.. tried one filter for the act still nothing showed.. not sure what im doing wrong..
95 gt vert,302 .040 over,VORTECH T TRIM (intercooled), AFRs185, TFS Track Heat & Stage 1 cam,BBK l/t headers & mid pipe, 75mm tb,80lbs inj,340lph,hpx maf,
Tuning with LC1, Moates QH, 2010 BE and EECA Sailorbob CBZA,j4j1.. stock T5
tbaggins
Re: dataloging??
Post by tbaggins » Wed Aug 08, 2012 10:33 pm
Seems like you select a diferent mode other than stock. Go to hardware > quarterhorse config > select the option that isnt mode0. (for me it is mode4:(2) four bank tunes)
Not 100%, I can't test for you either because I have parts on the car that aren't stock
I had the same problem initially and I think this is what I was told to do to solve it.
2003 Mustang GT , Custom EBAY Twin Turbo Fender mounted td05h-16g EVO III's, Electronic Boost Control, BA-3000 MAF, 47lb Ford Racing Injectors, 255lph fuel pump, Quarterhorse, BE/EA, Pops Racing RYAF1-XSH2 Strategy, Innovate LC1 w/Gauge, KB BAP, Built TR3650 - 550 ftlbs, 550 ftlb exedy clutch, 11 months of work, half my savings & 1 pissed off wife
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Thu Aug 09, 2012 1:07 am
Thanks I'll give that a try in the AM
boostednotch
Re: dataloging??
Post by boostednotch » Thu Aug 09, 2012 8:23 am
Try opening it in windows excel to make sure the log isn't empty..if its not then it should open..this is what Clint told me when I was having the same issue
1990 mustang stock bottomend, gt40p heads and intake, f303 cam, 42lb injectors, sctba2400 maf, 75mm tb, v3si trim 10psi with upr power pipe, msd 6a, msd streetfire coil, tuning QH BE
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Thu Aug 09, 2012 3:04 pm
boostednotch wrote:Try opening it in windows excel to make sure the log isn't empty..if its not then it should open..this is what Clint told me when I was having the same issue
opened it as a spreadsheet but all that came up were the names of the things i had checked on the payload nothing else
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Thu Aug 09, 2012 4:40 pm
tbaggins wrote:Seems like you select a diferent mode other than stock. Go to hardware > quarterhorse config > select the option that isnt mode0. (for me it is mode4:(2) four bank tunes)
ok that fixed some of it.. i had it on mode one switch to mode 2 wrote it on tue 2 and deleted everything else.. now im showing alot more in the dashboard but i cant open anything on eec anylizer.. tried the spread sheet but it still blank
markedforlife
Re: dataloging??
Post by markedforlife » Thu Aug 09, 2012 9:09 pm
Did you configure the ''Dashboard Parameter Details'' box?
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Thu Aug 09, 2012 11:04 pm
markedforlife wrote:Did you configure the ''Dashboard Parameter Details'' box?
No I did not.. Is there anything I have to do to it??
markedforlife
Re: dataloging??
Post by markedforlife » Thu Aug 09, 2012 11:37 pm
With Dashbord #1 open double click your rpm box and see if there is a capital N as the
payload tag name, this might fix the rpm problem.
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Fri Aug 10, 2012 12:19 am
markedforlife wrote:With Dashbord #1 open double click your rpm box and see if there is a capital N as the
switching modes fixed that.. theonlything now is when i try to open my datalog in EECA it says filter have cleared all rows but i have no filters enabled. i think my datalogs are blank.. i try to open them in a spread sheet but oly thing that came up was the things i checked on the payload
markedforlife
Re: dataloging??
Post by markedforlife » Fri Aug 10, 2012 12:35 am
Might have to do with the xml files that need deleted.
viewtopic.php?f=10&t=19480&p=108490&hil ... es#p108490
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Fri Aug 10, 2012 1:44 am
markedforlife wrote:Might have to do with the xml files that need deleted.
that souns exacly like whats happenin with me but i open the config folder there is no xml files there is some but its on the BE folder im not sure i should delete those..
tbaggins
Re: dataloging??
Post by tbaggins » Fri Aug 10, 2012 11:17 am
First of all, is BE logging now? You can view datalogs in BE as well as EA, just go to the chart area and open your most recent datalog. I was also thinking, is the tune that is loaded onto your QH the same tune that your using now? I save mine often under different names, and I am pretty sure I can't datalog unless the tune that is in the QH is the same tune that I have loaded.
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Fri Aug 10, 2012 12:23 pm
tbaggins wrote:First of all, is BE logging now? You can view datalogs in BE as well as EA, just go to the chart area and open your most recent datalog. I was also thinking, is the tune that is loaded onto your QH the same tune that your using now? I save mine often under different names, and I am pretty sure I can't datalog unless the tune that is in the QH is the same tune that I have loaded.
ok it shows i believe to be logging the et numbers keep going up..no matter how long i log tho my file stays the same size of 2kb.. i only have one tune.. not sure which chart are to open it in.. i dont see anywere in be to open it in
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Sat Aug 11, 2012 7:52 pm
this is what i see when i dataloging but i cant open anything..
rzfiveoh
Re: dataloging??
Post by rzfiveoh » Mon Aug 13, 2012 2:46 am
Fixed..xml files.. Thanks
Users browsing this forum: Bing [Bot] and 50 guests
