StangCrazy
Newbie to Tweecer?
Post by StangCrazy » Thu Dec 19, 2002 11:04 pm
I don't even know where to start and how to get programs that I can program the computer. Please give me some guidance.
MAYHEM1
new tweecer user
Post by MAYHEM1 » Sat Dec 21, 2002 10:50 pm
go to tweecer.com and go to downloads and download all the files available, put the files where they are routed to the usually go to program files under stkr folder and then open the caledit file and start changing parameters, but i will tell u have alot of problems with the files and i myself have no idea where to start
StangCrazy
Post by StangCrazy » Sun Dec 22, 2002 9:40 pm
How do you get to the Caledit file because I can not find it. It the first download all I need or do I need to do the RT one.
black sunshine
Post by black sunshine » Sun Dec 29, 2002 10:44 am
http://www.tweecer.com/downloads.html
download the full Rt setup, and when you get it, it will be the install for both Calcon and Caledit.
86 Gt Mass Air Conversion - gt40x heads, Lunati 51014, power plus intake, 65mm TB, 90mm cobra MAF, full exhaust, 255lb+t-rex, 42lb inj, 3:55's, tweecer, msd BTM
S-trim, AFM Powerpipe, Ramchargers Dual fans
StangCrazy
Post by StangCrazy » Thu Jan 02, 2003 10:02 pm
Which will I use to program the car the caledit or the calcon or do you use both. Thanks
93notch
Post by 93notch » Fri Jan 03, 2003 12:35 am
CalEdit is the interface to make changes to the calibration data and CalCon gives you feedback on what you have changed. You cannot write to the tweecer while CalCon is open so you must close it to access the tweecer with CalEdit. You can keep Caledit open and still use CalCon though.
Best regards,
Mike Glover
StangCrazy
Post by StangCrazy » Fri Jan 03, 2003 12:34 pm
Thanks for your help.
Users browsing this forum: Google [Bot] and 28 guests
