I've read that an injector low slope value is typically higher than the high slope value. It has been explained that for low pulsewidths, it acts like a bigger injector. That seems to make sense, but the injectors I actually have from Deatschworks (Part Number: 18u0100608) have the following values:
Low Slope: 0.014931 lb/s = 53.75 lb/hr
High Slope: 0.017817 lb/s = 64.14 lb/hr
Breakpoint: 2.09733E-5 lb
Min Pulsewidth: 0.725 ms
Static Flow: 62.9lb/hr
The high slope value is higher than the low slope. Does this make sense and is anyone else running injectors like this? (and using these values in their tune?)
91TurboFox
Re: Injector Low Slope Lower Flow than High Slope?
Not sure where you got those numbers......I had a look at their spread sheet for 86-04 Mustangs and there are 3 separate sets of data. One 2011+ for returnless systems which follows the arrangement you posted and the other two pretty much the same 39 psi and return system.
1987 Turbocoupe.
A3M1/A9L, BE/EA, Tweecer RT.
91TurboFox
Thanks John, I was using the datasheet posted to Summit's website (https://static.summitracing.com/global/ ... 20ford.pdf). I'm not sure why it's different (even compared to the 2011+ values it's different), as the same part numbers are listed. I'm just happy I have some numbers that make more sense to me.
Thanks again!
Thanks again!
Users browsing this forum: Google [Bot] and 23 guests
