Paul
Engineering or ms?
Post by Paul » Sat Jun 18, 2005 9:45 pm
Does the Tweecer take engineering notation or ms when inputting Injector Breakpoint as a function in the A9L?
For instance:
1. Engineering: 1.45
2. Milliseconds: 2.0
gt90stang
Post by gt90stang » Sat Jun 18, 2005 9:57 pm
3.0448 is the stock value. However, in the A9? series this is a fuel trim and not a true injector breakpoint so I just left it at stock even with 24# and 42# injectors.
Don
Paul
Post by Paul » Sat Jun 18, 2005 10:23 pm
gt90stang wrote:3.0448 is the stock value. However, in the A9? series this is a fuel trim and not a true injector breakpoint so I just left it at stock even with 24# and 42# injectors.
Don
That I knew, I was just wondering what the Tweecer takes.
gt90stang
Post by gt90stang » Sat Jun 18, 2005 11:06 pm
That is what Tweecer takes.
Don
Paul
Post by Paul » Sat Jun 18, 2005 11:26 pm
gt90stang wrote:That is what Tweecer takes.
Don
So is "that" in milliseconds or engineering notation?
Dale McPeters
Professional Tuner/Shop Owner
Post by Dale McPeters » Sun Jun 19, 2005 11:23 am
Don
Engineering notation. For example 3.0448 = 3.0448e-05, If I remember correctly....
BE & EEC Analyzer
Paul's EEC-Editor
PBR
Post by PBR » Sun Jun 19, 2005 11:39 am
Cool , thanks
Dale McPeters wrote: Engineering notation.
gt90stang
Post by gt90stang » Sun Jun 19, 2005 5:58 pm
Well,
I think it is actually in Milliseconds, but not because it is a fuel adder. so 3.0448 is what you put in Tweecer and it means 3.0448 x10^-3 seconds which is engineering notation or 3.0448 mS = 0.0030448 seconds. You're making this way too complicated?
Hope this helps, Don
Paul
Post by Paul » Sun Jun 19, 2005 6:29 pm
gt90stang wrote:Well,
I don't think so. I asked because 1.45-E5 does not look the same as 2 ms. EEC Analyzer lists engineering and ms, I wanted to know which one Tweecer took and thanks to Dale McPeters I now know.
gt90stang
Post by gt90stang » Sun Jun 19, 2005 6:47 pm
Ok, if it works then great. However, 3.0448e-05 is 30.448 uS or microseconds versus milliseconds, so it doesn't make sense to me. Just trying to understand what units they are using. 3.0448e-03 would be milliseconds.
Don
Dale McPeters
Post by Dale McPeters » Sun Jun 19, 2005 9:39 pm
Hey I did not mean to start an argument here........
Here is what I remember it to be as I have not messed with the software much in about 3-4 months........
INJECTOR_BREAKPOINT_VS_BATTERY_VOLTAGE # Injector Breakpoint table (Voltage, lbs/rev)
( 4095.94, 3.04478e-05 ) ( 0, 3.04478e-05 ) ( 0, 3.04478e-05 )
( 0, 3.04478e-05 ) ( 0, 3.04478e-05 ) ( 0, 3.04478e-05 )
The above is a snipit from the old EEC-Tuner software....as you can see the engineering notation 3.04478e-05 is lbs/rev.
Hope this helps.
BE & EEC Analyzer
Paul's EEC-Editor
Paul
Post by Paul » Sun Jun 19, 2005 10:46 pm
You didn't start an arguement, you answered my question. That's all I wanted to know, if Tweecer was looking for the engineering or milliseconds value.
Dale McPeters wrote:Hey I did not mean to start an argument here........
It really was as simple as that.
Cougar5.0
Post by Cougar5.0 » Sun Jun 19, 2005 10:59 pm
Paul wrote:You didn't start an arguement, you answered my question. That's all I wanted to know, if Tweecer was looking for the engineering or milliseconds value.
It's neither engineering notation (which is just in exponents that match notation - IE 10^-3 = mili or 10-6 = micro - exponents are always multiples of three) OR milliseconds according to Dale. It's lbs/revolution - which is a very small number 3.04 * 10^-5 lbs/revolution...
428w now
Paul
Post by Paul » Sun Jun 19, 2005 11:24 pm
Hmmm, before this gets to be a 4 or 5 page discussion of lb/rev, ms, exponents, phases of the moon etc...
Did anyone read my initial post? I believe Dale did as he answered the question for me.
Honestly, ALL I wanted to know was engineering value or ms value. Now that it has been answered and everyone involved understands what the question really was, I'd like to thank you all for your input and bid you good luck in your follow on discussion.
Cougar5.0
Post by Cougar5.0 » Mon Jun 20, 2005 11:08 am
Problem is, miliseconds is engineering notation too (10^-3 seconds) - the question was not clear - sorry, I guess I'm just an engineer busting your balls 8) :P
428w now
Paul
Post by Paul » Mon Jun 20, 2005 11:14 am
Cougar5.0 wrote:Problem is, miliseconds is engineering notation too (10^-3 seconds) - the question was not clear - sorry, I guess I'm just an engineer busting your balls 8) :P
My turn to bust yours then ;) I was asking about what the Tweecer was looking for ;) :lol: Anyways, the question was answered and my curiosity satisfied for now. Thanks again.
Dale McPeters
Post by Dale McPeters » Mon Jun 20, 2005 1:09 pm
Cougar5.0 wrote: It's neither engineering notation (which is just in exponents that match notation - IE 10^-3 = mili or 10-6 = micro - exponents are always multiples of three) OR milliseconds according to Dale. It's lbs/revolution - which is a very small number 3.04 * 10^-5 lbs/revolution...
Cougar5.0,
Technically you are correct on your math equations but that is not exactly what he was trying to ask. Maybe I should have said it like this...........
"It is more like an engineering value than it is milliseconds as it is in lbs/rev"
I said it was lbs/rev if you look at my post above and the snipit from the old EEC-Tuner software. It has (Voltage, lbs/rev)..............
Is that better? Does my math grade go up now? :lol:
I just do not want to get into different phases of the moon as Paul stated above............ :lol:
(Edit- I flunked English....... :lol: )
Last edited by Dale McPeters on Mon Jun 20, 2005 2:38 pm, edited 2 times in total.
BE & EEC Analyzer
Paul's EEC-Editor
gt90stang
Post by gt90stang » Mon Jun 20, 2005 1:36 pm
No argument here. I was looking at the injector breakpoint function and not injector breakpoint vs battery voltage mostly because that is what was asked :oops:
Good Luck, Don
Dale McPeters
Post by Dale McPeters » Mon Jun 20, 2005 2:04 pm
gt90stang wrote:No argument here. I was looking at the injector breakpoint function and not injector breakpoint vs battery voltage mostly because that is what was asked :oops:
Good Luck, Don
Don,
You were looking at the correct item, as the injector breakpoint function (under the Functions tab) is the one that relates to battery voltage.
I just did not word my replies well enough for Couger5.0 to comprehend what I was trying to get at.....I guess I will have to do better, as I do not like flunking class........ :lol:
BE & EEC Analyzer
Paul's EEC-Editor
Cougar5.0
Post by Cougar5.0 » Mon Jun 20, 2005 4:09 pm
Good Luck, Don
Don,
I wasn't criticizing you actually - the original question just doesn't make sense from a technical standpoint, that's all. I actually had the same question, but seeing as the original A9L program has 10^-5 scale units, it can't be milliseconds, so I figured it out on my own - it'a a good question actually! It's not something I want to argue about anyway - I was hoping to help but I think I just made things worse. Fughet about it
428w now
Dale McPeters
Post by Dale McPeters » Mon Jun 20, 2005 5:05 pm
Cougar5.0 wrote:I wasn't criticizing you actually - the original question just doesn't make sense from a technical standpoint, that's all. I actually had the same question, but seeing as the original A9L program has 10^-5 scale units, it can't be milliseconds, so I figured it out on my own - it'a a good question actually! It's not something I want to argue about anyway - I was hoping to help but I think I just made things worse. Fughet about it
I did not take it as a criticism at all as sometimes it is good to have a discussion/ribbing etc. like this as now Don and yourself have listed some good equations etc that others may need in the future. Besides I needed a short break from all the numbers & calculations that I am working on today at my real job. I try not to get too technical anymore as it makes my head hurt....... :? .....and sometimes confuses the ones that I try to help. And that is not a good thing.
I am just glad that Paul actually got the answer that he was looking for that is the main thing.
By the way if you have not noticed it takes quite a bit to upset me........did you not notice the ribbing that I was giving you about math & class?
BE & EEC Analyzer
Paul's EEC-Editor
gt90stang
Post by gt90stang » Mon Jun 20, 2005 9:56 pm
Dale & all,
Right on....we are just trying to help each other out. Communication is a two way street. GIGO but we work it out....man am I a Poet or what!
Don
Dale McPeters
Post by Dale McPeters » Tue Jun 21, 2005 6:56 am
gt90stang wrote:Dale & all,
Don
Don,
What poetry!!!
By the way since I am starting to become an old fart what exactly does GIGO mean......be easy on me..... :lol:
BE & EEC Analyzer
Paul's EEC-Editor
gt90stang
Post by gt90stang » Tue Jun 21, 2005 10:14 am
Dale,
It's an old computer term GIGO = Garbage in garbage out.
Don
Dale McPeters
Post by Dale McPeters » Tue Jun 21, 2005 11:02 am
gt90stang wrote:Dale,
Don
Don,
I thought that was what it was but just wanted to be sure as some of the abbreviations that are being posted now-a-days are sometimes not what you would think........ :lol:
BE & EEC Analyzer
Paul's EEC-Editor
Cougar5.0
Post by Cougar5.0 » Tue Jun 21, 2005 11:14 am
This thread will never die - it's becomming the "lounge" thread in the "Tweaking the EEK!!" forum :D
428w now
Dale McPeters
Post by Dale McPeters » Tue Jun 21, 2005 12:12 pm
:lol:
BE & EEC Analyzer
Paul's EEC-Editor
Users browsing this forum: No registered users and 173 guests
