Low RPM bucking... can it be cured?...
I just finished tuning a friends car on his TwEECer, he has a 90LX, 347, 10.5:1 compression, all of the goodies, stout motor. He likes driving his car in his neighborhood at very low RPM's for noise reasons and I can't talk him out of it. I have drivability nailed on it perfectly, but when he gets down around 1500rpm, it starts to buck really bad. I attribute 95% of this to the cam... it's bassicaly a .600 lift B303 cam (I can't remember the exact specs right off of the top of my head). Is there ANYTHING I can do to try to remedy this at all? I don't think there is, but I could be wrong. Please let me know if you have any ideas, thanx!
-Don-
87' GT, A9L, TwEECer RT, P1SC@12psi Non-Intercooled, AFM PP, 3" Pro-M#42, 70mm TB, GT-40 Intake, GT-40X Heads, B303, 1.6, BBK 1-5/8" Long Tubes, 306 Built Bottom End, Probe Block Girdle, TR3550, 3.55, PLX WB, Jan 07 Modified Mustangs Feature Car
That's just it though... the KAMRF's on his car are damn near perfect... that's why I say it's probibly the cam, maybe something with timing, I don't know... Mine with the B303 cam is perfect down low as well, but I can get another 300-400 out of it... that could just be the difference in cams though. I don't ever drive my car down that low so I don't care... but he does.
-Don-
My KAMRF's where perfect as well but commanded was in the 16 - 17 range. It took my wideband to get it right. Now the KAMRF's = commanded = wideband and all is right in the worldWA2FAST wrote:That's just it though... the KAMRF's on his car are damn near perfect... that's why I say it's probibly the cam, maybe something with timing, I don't know... Mine with the B303 cam is perfect down low as well, but I can get another 300-400 out of it... that could just be the difference in cams though. I don't ever drive my car down that low so I don't care... but he does.
- Jack Hidley
A friend of mine, Nate, solved this problem a while ago. Here is the link to the problem and solution he posted.
viewtopic.php?t=5434&highlight=
It has always shocked me that Ford wasn't able/willing to solve this problem on the several hundred thousand EEC-IV/V Mustangs that they sold over the years.
Jack Hidley
Looks good, thank you very much for the info, I'll give that a shot the next time I work on the car.
-Don-
Users browsing this forum: Bing [Bot] and 41 guests
