SVTCobra50
Tweecer writing to multiple positions...
Post by SVTCobra50 » Mon Apr 28, 2003 12:27 pm
Mine is doing the same thing. I am waiting 10 seconds between writes and this is concerning me.
And 1 more weird thing...Is anyone else having this happen :arrow:
When i make some changes to a tune, I start the car up and it idles fine. Then when i try to drive it just dies and is extremely hard to start :( It starts and misses, sputters and dies if you try to let out on the clutch.
I thought it was a fluke, so i started fresh and made the same changes to a eec bin file and saved. The tune worked for a day then the next time I changed the littlest thing, it bombed again.
desmo996
Post by desmo996 » Mon Apr 28, 2003 12:51 pm
I don't have the double write problem, but I have had your second problem a couple times. I don't know a fix, I figured it might make you feel better to know you are not alone.
I have read from time to time to double check the last values in your MAF transfer to make sure it hasn't by some magical force changed to a "0"
95 Opal Frost GT J4J1 Cal. TwEECer v1.20B3 PATIENTLY awaiting v1.3whatever :)
93notch
Post by 93notch » Mon Apr 28, 2003 2:36 pm
Hmm, well Chris Mureen has reported having the same problem and I have not been able to replicate the problem. I am adding an extra verification of the encryption process to double check the file before saving to disk and after reading from the TwEECer.
Best regards,
Mike Glover
SVTCobra50
Post by SVTCobra50 » Mon Apr 28, 2003 2:53 pm
Which problem Mike?
93notch
Post by 93notch » Mon Apr 28, 2003 3:24 pm
Did you get yours during the DFWStangs Group purchase or more recently? What does the Board Rev display after reading/writing the tweecer??
I was referring to the problem of your tuning mods getting corrupted.
Best regards,
Mike Glover
SVTCobra50
Post by SVTCobra50 » Mon Apr 28, 2003 5:35 pm
It was about 2 weeks ago (from dynotune perf) and it was not associated with the dfwstangs GP.
Will get the board rev for you asap. :wink:
93notch
Post by 93notch » Mon Apr 28, 2003 5:51 pm
ooops!! :oops: Sorry, I cannot keep everyone straight, too many tweecies out there now.......
Best regards,
Mike Glover
SVTCobra50
Post by SVTCobra50 » Wed May 07, 2003 11:31 am
Sorry it took a few days, but the board rev is R5101R00E
-Dustin
94 Cobra - J4J1 Tweecer v1.20B3, Low comp 331ci, 42# inj, Novi 2000
SVTCobra50
Post by SVTCobra50 » Tue May 20, 2003 12:36 pm
TTT.
-Dustin
Ghudnub
Re: Tweecer writing to multiple positions...
Post by Ghudnub » Tue May 20, 2003 1:06 pm
SVTCobra50 wrote: And 1 more weird thing...Is anyone else having this happen :arrow:
I've said before that my old LPT Tweecer was doing this when I switched to the 1.20B3 LPT software. My wideband shows 14.7 a/f at idle, all is smooth, then as soon as you start the car in motion the a/f ratio goes so lean that the display can't show it, >25:1. This only happens with 1.20B3 though. I wonder if there is some glitch in the encoding/decoding?
Someone mentioned that the MAF transfer may be getting corrupted, maybe a zero where one shouldn't be? I dunno, I just use version 1.18 instead. Later.
Greg
'95 GTS lives on in '00 V6 body! 347, J4J1, LPT, 6037's w/Comp Beehives, Extrude honed Cobra, 75mm TB, 87mm Pro-M, TFS Stage 2, 1.7's, 30#r's, LT's, Offroad X-pipe, Bassani catback, and every suspension tweak except for a torque arm.
Ziggy
Post by Ziggy » Sun May 25, 2003 10:56 am
93notch wrote:I am adding an extra verification of the encryption process.
Encryption? What is that for? In case somebody hacks my computer they cannot read my config? :roll:
Users browsing this forum: Google [Bot] and 36 guests
