wa_4x4builder
Canister purge disable switch?
In the strategy document for the A9L, there is mention of a scalar named CANPHP to disable the canister purge sub-system. I can't seem to find that in CalEdit. Anyone have an idea of where I might find it or did I just overlook it on my first pass through the scalars?
Thanks!
Thanks!
'93 EDIS 5.0L with A9L installed into a '77 Bronco.
I don't see the exact scalar that you are speaking of, but there is one called Canister Purge Open Loop Enable (PURGSW) that should fit the bill. Also right above that one is Canister Purge Minimum RPM (EVRPM). This is assuming you are using the A9L bin that comes with CalEdit and the A9L strategy.
Justin
Justin
Justin
93 A3M (A9L), 331, 30lbs inj., '02GT MAF, Trick Flow 'R' intake, Tremec TKO, 3.55's
2001 GT automatic with NUX1 stock.
TwEECer RT
TwEECer RT
wa_4x4builder
I was hoping to disable the sub-system, including the KOEO tests for the CANP system, thus eliminating my one last trouble code. I'm not sure setting the min RPM will do the trick, but I will give it a try and determine what happens.J_P wrote:I don't see the exact scalar that you are speaking of, but there is one called Canister Purge Open Loop Enable (PURGSW) that should fit the bill. Also right above that one is Canister Purge Minimum RPM (EVRPM). This is assuming you are using the A9L bin that comes with CalEdit and the A9L strategy.
Justin
Thanks for the pointers,
Chris
Dale McPeters
Set
Canister Min. RPM = 8000
Canister Open Loop Enable = 0
Checksum base address = 0
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
wa_4x4builder
I just changed these values and re-ran the KOEO tests- the code 85 I am getting still exists. I really think the CANPHP is the key here. It's mentioned in the strategy document. I haven't had any time to research its hex address (if it can be found), but it would be nice to add this scalar, if possible.Dale McPeters wrote:Set
Thanks for suggestions everyone.
Dale McPeters
His name is Lee Hay. He is a friend of mine that lives in Odessa. We did some "horse" trading on all the new parts that he had bought for the 418w stroker etc. back in 2003-2004 that he has never had time to put together. Now the 418 parts are in my shop awaiting to be assembled if I ever quit working 7 days a week at the office..........EFIpunk wrote:Dale...who is Lee H.?
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
Dale McPeters
Did you clear KAM before re-running the test?wa_4x4builder wrote:I just changed these values and re-ran the KOEO tests- the code 85 I am getting still exists. I really think the CANPHP is the key here. It's mentioned in the strategy document. I haven't had any time to research its hex address (if it can be found), but it would be nice to add this scalar, if possible.Dale McPeters wrote:Set
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
Dale McPeters
Also one other thing you may also want to set the
Thermactor Air Control Logic = 0
Depending on what all is removed from the system.
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
wa_4x4builder
Yes, I reset the KAM. But, I might have screwed upDale McPeters wrote:Also one other thing you may also want to set the
I also set the Thermactor to 0 and the EGR to 2. I'm on a mission to remove emissions goo
Dale McPeters
Let us know what happens....
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
According to useful tuning info.doc after you disable it you can:
Eliminate Purge Can Solenoid
Replace solenoid with 10K resistor
Good Luck, Don
Good Luck, Don
wa_4x4builder
No Luck... Same code 85 shows with the KOEO test.Dale McPeters wrote:Let us know what happens....
I can't install the resister because the wires have been physically removed from the harness.
Hmmm, I'll try the other suggestion of setting the scalar to 9999, but I don't think that will help things. It's worth a try, though. Any other suggestions while I am in there fiddling around?
Thanks.
you need to start with the S0Z binary:
viewtopic.php?p=32724
S0Z has the CANP test disabled (not something avalible with CalEdit)
Ryan McCormick
Ford Fuel Injection.com
Dale McPeters
Ryan is correct it is not available in Caledit, but if you have an older version of the EEC-Editor or GUI-Pro you can access these......
BE & EEC Analyzer
Paul's EEC-Editor
BE & EEC Analyzer
Paul's EEC-Editor
Users browsing this forum: Google [Bot] and 84 guests
