wa_4x4builder
Canister purge disable switch?
Post by wa_4x4builder » Tue Jun 21, 2005 11:15 pm
In the strategy document for the A9L, there is mention of a scalar named CANPHP to disable the canister purge sub-system. I can't seem to find that in CalEdit. Anyone have an idea of where I might find it or did I just overlook it on my first pass through the scalars?
Thanks!
'93 EDIS 5.0L with A9L installed into a '77 Bronco.
J_P
Post by J_P » Wed Jun 22, 2005 3:24 am
I don't see the exact scalar that you are speaking of, but there is one called Canister Purge Open Loop Enable (PURGSW) that should fit the bill. Also right above that one is Canister Purge Minimum RPM (EVRPM). This is assuming you are using the A9L bin that comes with CalEdit and the A9L strategy.
Justin
Justin
93 A3M (A9L), 331, 30lbs inj., '02GT MAF, Trick Flow 'R' intake, Tremec TKO, 3.55's
2001 GT automatic with NUX1 stock.
TwEECer RT
wa_4x4builder
Post by wa_4x4builder » Wed Jun 22, 2005 9:53 am
J_P wrote:I don't see the exact scalar that you are speaking of, but there is one called Canister Purge Open Loop Enable (PURGSW) that should fit the bill. Also right above that one is Canister Purge Minimum RPM (EVRPM). This is assuming you are using the A9L bin that comes with CalEdit and the A9L strategy.
Justin
I was hoping to disable the sub-system, including the KOEO tests for the CANP system, thus eliminating my one last trouble code. I'm not sure setting the min RPM will do the trick, but I will give it a try and determine what happens.
Thanks for the pointers,
Chris
Dale McPeters
Post by Dale McPeters » Wed Jun 22, 2005 10:28 am
Set
Canister Min. RPM = 8000
Canister Open Loop Enable = 0
Checksum base address = 0
BE & EEC Analyzer
Paul's EEC-Editor
EFIpunk
Post by EFIpunk » Wed Jun 22, 2005 10:35 am
Dale...who is Lee H.?
'88 Fox: 347ci.T88 at 20psi.83inj.A9L.TwEECerRT w/BE
wa_4x4builder
Post by wa_4x4builder » Wed Jun 22, 2005 10:52 am
Dale McPeters wrote:Set
I just changed these values and re-ran the KOEO tests- the code 85 I am getting still exists. I really think the CANPHP is the key here. It's mentioned in the strategy document. I haven't had any time to research its hex address (if it can be found), but it would be nice to add this scalar, if possible.
Thanks for suggestions everyone.
Dale McPeters
Post by Dale McPeters » Wed Jun 22, 2005 10:55 am
EFIpunk wrote:Dale...who is Lee H.?
His name is Lee Hay. He is a friend of mine that lives in Odessa. We did some "horse" trading on all the new parts that he had bought for the 418w stroker etc. back in 2003-2004 that he has never had time to put together. Now the 418 parts are in my shop awaiting to be assembled if I ever quit working 7 days a week at the office.......... :lol:
BE & EEC Analyzer
Paul's EEC-Editor
Dale McPeters
Post by Dale McPeters » Wed Jun 22, 2005 11:07 am
Did you clear KAM before re-running the test?
BE & EEC Analyzer
Paul's EEC-Editor
Dale McPeters
Post by Dale McPeters » Wed Jun 22, 2005 11:26 am
Also one other thing you may also want to set the
Thermactor Air Control Logic = 0
Depending on what all is removed from the system.
BE & EEC Analyzer
Paul's EEC-Editor
wa_4x4builder
Post by wa_4x4builder » Wed Jun 22, 2005 12:01 pm
Dale McPeters wrote:Also one other thing you may also want to set the
Yes, I reset the KAM. But, I might have screwed up :shock: I yanked the battery cable off while heading out of the garage for work. I'll give it a re-test when I get home tonight.
I also set the Thermactor to 0 and the EGR to 2. I'm on a mission to remove emissions goo :P
Dale McPeters
Post by Dale McPeters » Wed Jun 22, 2005 12:07 pm
Let us know what happens....
BE & EEC Analyzer
Paul's EEC-Editor
gt90stang
Post by gt90stang » Wed Jun 22, 2005 1:05 pm
According to useful tuning info.doc after you disable it you can:
Eliminate Purge Can Solenoid
Replace solenoid with 10K resistor
Good Luck, Don
1990 GT, A9P, v1.30A9, 306ci, 76mm C&L, Explorer (GT40) lower, KB Blowzilla 8#, 42# inj, Edelbrock 6037 aluminum heads 2.02 / 1.6 valves, Crane 2030 cam...way more.
wa_4x4builder
Post by wa_4x4builder » Wed Jun 22, 2005 10:43 pm
Dale McPeters wrote:Let us know what happens....
No Luck... Same code 85 shows with the KOEO test.
I can't install the resister because the wires have been physically removed from the harness.
Hmmm, I'll try the other suggestion of setting the scalar to 9999, but I don't think that will help things. It's worth a try, though. Any other suggestions while I am in there fiddling around?
Thanks.
fireguy50
Post by fireguy50 » Fri Sep 23, 2005 10:03 pm
you need to start with the S0Z binary:
viewtopic.php?p=32724
S0Z has the CANP test disabled (not something avalible with CalEdit)
Ryan McCormick
Ford Fuel Injection.com
Dale McPeters
Post by Dale McPeters » Fri Sep 23, 2005 10:48 pm
Ryan is correct it is not available in Caledit, but if you have an older version of the EEC-Editor or GUI-Pro you can access these......
BE & EEC Analyzer
Paul's EEC-Editor
Users browsing this forum: No registered users and 112 guests
