- PoweredbyEECV
Need correct address for VBAT in CRAJ0 Def file
The current address for VBAT in the CRAJ0 definition file with BE may be incorrect. When data logging it always displays and logs a 3 digit value such as 931.00 which is obviously way out of range. Can someone that knows how to verify address locations check and determine what the correct address is? The payload tab currently lists 0x0761 as the address for VBAT. I would appreciate any assistance.
Thank you,
Thank you,
Last edited by PoweredbyEECV on Wed May 12, 2010 12:40 pm, edited 1 time in total.
98 SVT Cobra Convertible - Laser Red/Saddle/Saddle #2906 of 3480
BE - Version 2009 Build 39
Definition: CRAJ0
Binary file : AOL3
Tuning & Data Logging PC: Acer Aspire One Netbook, 1.60 GHz, 1.48 GB Ram - Windows XP HE SP3
TWEECER-RT with BE & EA Software, DataQ 148U for AFR & 3 bar MAP sensor, Wide Band Commander, KAM clearing switch.
Stock Engine w/: V1, S-Trim w/AC @ 10 PSI, 60 lbs injectors, T-Rex FP, FP set at 45 psi, no FMU. Custom CAI, IAT relocated, ProM-77 MAF. Scream'in Demon coil packs and Live Wires.
Definition: CRAJ0
Binary file : AOL3
POPSRACING
Re: Need correct address for VBAT in CRAJ0 Def file
pm'd you
Land and Sea chassis dyno
1995 Cobra, 408, sold...
- PoweredbyEECV
Pops,
I contribute many hours of my own time adding descriptions for definations.
Last edited by PoweredbyEECV on Thu May 13, 2010 6:24 pm, edited 2 times in total.
Definition: CRAJ0
Binary file : AOL3
Definition: CRAJ0
Binary file : AOL3
Change the number of bytes from 2 to 1.
POPSRACING
Your preaching to the choir, is this Brian? I'm sure a few other could jump in and make the same statement, Mike?
Who, me? I get the feeling that I've missed half of an interesting conversation........ are there finally more geeks coming out to play?POPSRACING wrote:Your preaching to the choir, is this Brian? I'm sure a few other could jump in and make the same statement, Mike?
As has been said, (perhaps not enough) on these processors, you can always be suspicious of 2 byte variables with an odd numbered address.
There's more than just an address that will make datalogging difficult.
Michael
- PoweredbyEECV
Sailorbob,
I did as you suggested and VBAT now reads correctly.
Thank you for the help
Definition: CRAJ0
Binary file : AOL3
Definition: CRAJ0
Binary file : AOL3
man i want a piece instead of 2 to 1 try 4... worked for me
Any one have the address for VBAT in CBAZA (T4M0 eec) for use in editor v2.2?
-Clint-
Anything CBAZA, you can open the open source def file for BinaryEditor to find the offset. Just keep in mind the value as it exists in the def file is adjusted for a NON-buffered BIN file as it relates to the Scalar/Function/Tables. However payload items, I believe, are in normal format.
Tired that... Clint said the same thing with that file, didn't have any luck with it loging... I think I have the byte/bit/word/etc mested upcgrey8 wrote:Anything CBAZA, you can open the open source def file for BinaryEditor to find the offset. Just keep in mind the value as it exists in the def file is adjusted for a NON-buffered BIN file as it relates to the Scalar/Function/Tables. However payload items, I believe, are in normal format.
-Clint-
BillMarkViii
- BIN Hacker
Sure you don't have it wired directly to the power lines?PoweredbyEECV wrote:The current address for VBAT in the CRAJ0 definition file with BE may be incorrect. When data logging it always displays and logs a 3 digit value such as 931.00 which is obviously way out of range. Can someone that knows how to verify address locations check and determine what the correct address is? The payload tab currently lists 0x0761 as the address for VBAT. I would appreciate any assistance.
Thank you,
I show it at 760-761
word sized at 760,
byte sized at 761
VBAT is a 1 byte value at 0x331. A voltage of 12.0 Volts in that byte would be a value of 0xC0 in the byte.cdMueller wrote:Any one have the address for VBAT in CBAZA (T4M0 eec)
Can't help you with that part, I'm afraid.cdMueller wrote: for use in editor v2.2?
