PoweredbyEECV
Need correct address for VBAT in CRAJ0 Def file
Post by PoweredbyEECV » Tue May 11, 2010 9:07 pm
The current address for VBAT in the CRAJ0 definition file with BE may be incorrect. When data logging it always displays and logs a 3 digit value such as 931.00 which is obviously way out of range. Can someone that knows how to verify address locations check and determine what the correct address is? The payload tab currently lists 0x0761 as the address for VBAT. I would appreciate any assistance.
Thank you,
Last edited by PoweredbyEECV on Wed May 12, 2010 12:40 pm, edited 1 time in total.
98 SVT Cobra Convertible - Laser Red/Saddle/Saddle #2906 of 3480
BE - Version 2009 Build 39
Definition: CRAJ0
Binary file : AOL3
Tuning & Data Logging PC: Acer Aspire One Netbook, 1.60 GHz, 1.48 GB Ram - Windows XP HE SP3
TWEECER-RT with BE & EA Software, DataQ 148U for AFR & 3 bar MAP sensor, Wide Band Commander, KAM clearing switch.
Stock Engine w/: V1, S-Trim w/AC @ 10 PSI, 60 lbs injectors, T-Rex FP, FP set at 45 psi, no FMU. Custom CAI, IAT relocated, ProM-77 MAF. Scream'in Demon coil packs and Live Wires.
POPSRACING
Re: Need correct address for VBAT in CRAJ0 Def file
Post by POPSRACING » Wed May 12, 2010 9:46 am
pm'd you
Land and Sea chassis dyno
1995 Cobra, 408, sold...
PoweredbyEECV
Post by PoweredbyEECV » Wed May 12, 2010 1:22 pm
Pops,
I contribute many hours of my own time adding descriptions for definations.
Last edited by PoweredbyEECV on Thu May 13, 2010 6:24 pm, edited 2 times in total.
Definition: CRAJ0
Binary file : AOL3
Post by sailorbob » Wed May 12, 2010 2:16 pm
Change the number of bytes from 2 to 1.
POPSRACING
Post by POPSRACING » Wed May 12, 2010 2:24 pm
Your preaching to the choir, is this Brian? I'm sure a few other could jump in and make the same statement, Mike?
mpaton
Post by mpaton » Wed May 12, 2010 4:54 pm
POPSRACING wrote:Your preaching to the choir, is this Brian? I'm sure a few other could jump in and make the same statement, Mike?
Who, me? I get the feeling that I've missed half of an interesting conversation........ are there finally more geeks coming out to play?
As has been said, (perhaps not enough) on these processors, you can always be suspicious of 2 byte variables with an odd numbered address.
There's more than just an address that will make datalogging difficult.
Michael
PoweredbyEECV
Post by PoweredbyEECV » Thu May 13, 2010 9:34 pm
Sailorbob,
I did as you suggested and VBAT now reads correctly.
Thank you for the help
Definition: CRAJ0
Binary file : AOL3
Post by decipha » Fri May 14, 2010 6:49 pm
man i want a piece instead of 2 to 1 try 4... worked for me
:lol:
cdMueller
Post by cdMueller » Thu May 20, 2010 2:48 pm
Any one have the address for VBAT in CBAZA (T4M0 eec) for use in editor v2.2?
-Clint-
Post by cgrey8 » Thu May 20, 2010 4:12 pm
Anything CBAZA, you can open the open source def file for BinaryEditor to find the offset. Just keep in mind the value as it exists in the def file is adjusted for a NON-buffered BIN file as it relates to the Scalar/Function/Tables. However payload items, I believe, are in normal format.
cdMueller
Post by cdMueller » Thu May 20, 2010 5:33 pm
cgrey8 wrote:Anything CBAZA, you can open the open source def file for BinaryEditor to find the offset. Just keep in mind the value as it exists in the def file is adjusted for a NON-buffered BIN file as it relates to the Scalar/Function/Tables. However payload items, I believe, are in normal format.
Tired that... Clint said the same thing with that file, didn't have any luck with it loging... I think I have the byte/bit/word/etc mested up
-Clint-
BillMarkViii
Post by BillMarkViii » Sun Jun 20, 2010 11:23 am
PoweredbyEECV wrote:The current address for VBAT in the CRAJ0 definition file with BE may be incorrect. When data logging it always displays and logs a 3 digit value such as 931.00 which is obviously way out of range. Can someone that knows how to verify address locations check and determine what the correct address is? The payload tab currently lists 0x0761 as the address for VBAT. I would appreciate any assistance.
Thank you,
Sure you don't have it wired directly to the power lines? :lol:
I show it at 760-761
word sized at 760,
byte sized at 761
mpaton
Post by mpaton » Mon Jun 21, 2010 5:02 pm
cdMueller wrote:Any one have the address for VBAT in CBAZA (T4M0 eec)
VBAT is a 1 byte value at 0x331. A voltage of 12.0 Volts in that byte would be a value of 0xC0 in the byte.
cdMueller wrote: for use in editor v2.2?
Can't help you with that part, I'm afraid.
