Where are all the tech docs?
t'would be nice if all the tech docs were in one easy to get to location, im looking for crai8 or craj0, i had both of them on my old laptop, anyone have a copy? either post it here or email me a copy
decipha at efidynotuning dot com
Re: Where are all the tech docs?
There were some disturbing moves going on over on FordFuelInjection.com relating to lawsuits over copyrighted or intellectual property being posted there without permission from Ford. I proactively moved the strategy docs where they couldn't be accessed until the dust settles and to see what comes of that. If things have calmed down, I can move them back to public view.
Which by the way, is now oldfuelinjection.com
For now anyway.
For now anyway.
Is there a document for CBAZA?
Or are the others close enough to it?
87 LX N/A 2.3 - CZAJL & EDIS
- Beach Mustang
Has this issue been resolved? I'm looking for CRAJO for car 3.
I know about Pops Racing. Anyone know how much they charges?
Car # 1: 1989 Mustang GT Conv; Tweecer RT, BE/EA, A9L, FRPP E cam crate motor, Twin T3/T4 Turbo's, GT40 intake, 90MMLMAF, 70mm Tbody, 42lbs injectors, 255lph Fuel pump, MSD 6A box and distributer, T56 Trans, BBK X pipe w/cats, flowmaster cat back, 373 Rear end
Car # 2: 1985.5 SVO,Tweecer RT, BE/EA, LA3, 90MMLMAF, 65MM Throttle Body, Water to Air Cooler
Car # 3: 1989 Mustang Coupe; Tweecer RT, BE/EA, AOL3, 98 Cobra Motor and trans, 04 IRS.
http://www.beachmustang.com
- Disney Lincoln
You can buy the POPSRACING strats through the Moates.net website. I think they are $200 for most strats. money WELL spent.
- Beach Mustang
Still trying to exhaust the free avenues before I go that route.
There's a time and place to skimp. But in this case, I'm afraid you'll be doing yourself a HUGE dis-service by not getting a paid-for def.Beach Mustang wrote:Still trying to exhaust the free avenues before I go that route.
- Beach Mustang
I hear ya. But I'm in no hurry and the paid avenue will always be there if needed.
That's true. But the unpaid def may lead you to learning conclusions that are false or misleading.
- Beach Mustang
But the unpaid version might come from someone that is currently using it and is tested.
Like I said I'm in no hurry. It will pop up somewere sooner or later. The car is completely stock for now. When i get the this issue resolved I'll move on to mods.
Thanks for the replys
- Beach Mustang
Got it.
Thanks to the member that shared.
Great site!
Great site!
Could anyone with a definition document for CBAZA please contact me?
I'm looking for the equivalent of the GUFB.
Jason
Jason
What is a defenition document? Does it break thing down better?vristang wrote:Could anyone with a definition document for CBAZA please contact me?
Jason
95 gt vert,302 .040 over,VORTECH T TRIM (intercooled), AFRs185, TFS Track Heat & Stage 1 cam,BBK l/t headers & mid pipe, 75mm tb,80lbs inj,340lph,hpx maf,
Tuning with LC1, Moates QH, 2010 BE and EECA Sailorbob CBZA,j4j1.. stock T5
From the sounds of it Ford is putting in some effort to keeping these documents confidential... for good reason I guess, as the documents basically outline every operating procedure programmed into the ecu.rzfiveoh wrote:What is a defenition document? Does it break thing down better?vristang wrote:Could anyone with a definition document for CBAZA please contact me?
Jason
For example, all the parameters affecting Fuel would be defined, all of the calculations layed out, and all of the logic documented.
I first looked at the GUFB (defining document for the A9L's) when looking at the TPS. It wasn't written for the layman, but it defines exactly how the TPS is used... and why .998v means nothing to the ecu.
I'm having trouble seeing how my lambse numbers are being derived, so I was hoping to see the CBAZA document.
