Just thought it was cool, and it'll make my life a hell of alot easier for this coming year, especially while trying to get a new bullet together and dialed in for it!
Moates Quarterhorse now a legal "add-on" in Factory Stock
I forgot to post up my pleasure about this back when the NMRA released the rules. One of my biggest hurdles when I started racing NMRA Factory Stock was NOT being able to use my trusted Moates Quarterhorse. I would have to dial in my tune, then have my buddy @ X&M Hot Rods transfer my tune over to a Diablo chip. Once on that and I was at the track there was no turning back so fueling and timing had to be finagled the old school way. Well I figured it wouldn't hurt to put in a rules request to have the QH legalized so I did, knowing I would be the only current racer who cared. Turns out it got approved as long as I remove the download cable.
1986 Mustang LX, 1997 Explorer Long Block, GT40P Heads never pulled off s/b, Explorer intake, 70MM TB. Converted to MAF using A9l GUFB strategy, 03-04 Maf, Scotty Brown custom cam, TFS springs/retainers/pushrods, BBK LT Headers and Xpipe, Dyno Max welded muffs, UD pulleys, Polished/Coated 4.30 gears, Z-code T5, Moates Quarterhorse, Binary Editor. 11.68@113.65 mph at Milan Dragway, 11-9-13. 1.54 60FT On BFG DR's. http://www.tooslo86.com/
Re: Moates Quarterhorse now a legal "add-on" in Factory Stoc
why didn't you just burn it to an f3 chip from moates ?? its only $60 + $75 for the jaybird to write them
It probably wasn't approved for use either.
Well one because as Chris said, it wasn't legal either, and two, because it never cost me anything whenever I needed to have it burnt to the Diablo. That's his way of sponsoring me, well, and discounts on time on the rollers ;)
if the diablo chip is legal the moates chip should be, whats the difference?
The Diablo chip is called out on the rules, the Moates isn't.
can't you just swap the connectors? their identical otherwise
Users browsing this forum: No registered users and 8 guests
