Chucko
QH battery temporary workaround
Post by Chucko » Mon Aug 11, 2014 12:55 pm
I've recently had the dead Quarterhorse battery problem turn up on my '89 Fox body Mustang. I found a workaround until I can replace the battery or the QH.
It's simple: While the engine is still running, plug in a cheap USB charger into the cigarette lighter, and plug the QH cable into the charger.
Obviously this is only going to work for a couple days at a time, but if you need to drive somewhere without your laptop, it will get you there and back.
Stengun
Re: QH battery temporary workaround
Post by Stengun » Tue Aug 12, 2014 10:59 am
Howdy Chucko,
Been there, done that too.
Moate's will repair or replace your QH free of charge, all you have to do is pay shipping to them. Fast turn around too.
Paul
Chucko
Post by Chucko » Fri Aug 15, 2014 11:29 pm
Thanks Stengun. I've already been in contact with Moates support, and that's what they told me. I'm using the opportunity to get an F3 and Jaybird so I can "set-and-forget" and not worry about batteries while my QH is in the shop.
phutch11
Post by phutch11 » Wed Sep 17, 2014 6:54 pm
Mine just died...was thinking about desoldereding it on my own, glad I saw this post!
1966 Mustang, 5.0 EFI Swap, Ported GT-40p Heads, 1.6 Roller Rockers, Explorer Intake, E-cam, 76mm C&L MAF (blue tube), 70mm Edelbrock TB, 42 lb injectors, Tri-Y Headers, T-5, 3.55 Gears, T4MO, QH, BE/TP, 6psi Powerdyne
Stengun
Post by Stengun » Thu Sep 18, 2014 9:57 pm
Howdy phutch,
phutch11 wrote:Mine just died...was thinking about desoldereding it on my own, glad I saw this post!
I thought the same thing until I pulled the QH out and looked at it.
Much, much easier just to ship it back to Moate's.
Paul
Post by decipha » Fri Sep 19, 2014 9:44 pm
just take a D battery with a couple wires and back charge the soldering joints for the battery, should be good for a couple months
Stengun
Post by Stengun » Sat Sep 20, 2014 9:00 pm
Howdy,
decipha wrote:just take a D battery with a couple wires and back charge the soldering joints for the battery, should be good for a couple months
Actually it will take two D cell batteries for 3VDC to charge the QH's 3VDC battery.
This would be a short term fix but it's still easier to return it to Moate's.
When my battery died the QH would work fine as long as it was connected to my laptop so any device that will connect to the QH's data cord should provide power to the QH.
Paul
Users browsing this forum: No registered users and 30 guests
