93notch
Post by 93notch » Sat May 08, 2004 7:13 pm
tms217 wrote:I dont have another... I'll see if I can find someone that will let me use theirs...
Here are somemore #'s at WOT.. You can see an almost 1 full second it skips during it..
126.943
127.784
128.205
Which Strategy are you using with your Cobra? Can you send me a 4 bank copy of your stock binary??
Best regards,
Mike Glover
wkstill
Post by wkstill » Mon May 10, 2004 6:47 pm
Did you try changing you PC color depth ?
try 16bit, 24bit, 32bit as well, i noticed it would make a diff sometimes on refresh speed.
Gt40x Heads, X303 ValveTrain, E303 Cam., A3M EEC-IV --- SOLD 3/2016
73mm C&L Maf, 65mm TB, 67mm EGR, Power+Plus Typhoon Intake, 24lb/Hr Inj.
1998 4R70W Tranny, Controlled by Bauman TCS, w/Level 3 Bauman Shift Kit, 2400 Edge Racing Stall., 3.73 Trac Lock 8.8 Rear.
shonut
Post by shonut » Mon May 10, 2004 7:00 pm
wkstill wrote:Did you try changing you PC color depth ?
note that the speed is not always inversely proportional to the colour depth, i.e. 24 may be faster than 16 ....
Regards,
Joshua Teixeira,
SHO NUT Performance
TwEECer RT Reseller
www.shonutperformance.com
sales@shonutperformance.com
EEC Analyzer User - now with one-step WB-based MAF tuning
http://EECAnalyzer.webhop.net
tms217
Post by tms217 » Tue May 11, 2004 6:05 am
Ill try It. 93 Notch, I'll get the information tonight. The laptop is at the other house.
1988 Notch 306
1999 Lightning
2011 F250 Powerstroke
2012 BMW S1000RR
tms217
Post by tms217 » Tue May 11, 2004 4:17 pm
126.943
127.784
128.205
with 130A8 I used RVAFA and when I tried to use the RVAFA on the 130A9 it did not work. However, the RVAF3 looks the same as the old RVAFA but it does not have any paylods. I did get the RVAF2 to work and seems to run fine with the payloads. Before and after the 130A9 I was having this problem. It was fine on the (i think it was) 130A7 but now when I try to log anything It skips. You should get the binary soon via email..
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Tue May 11, 2004 4:27 pm
BTW.. Itried to change the color depth and res and nothing seems to help. What would happen if I went to Win 98 from XP? What if I got USB 2.0? I'll be logged on AOL as SilverKobra2001 if anyone wants to talk a bit tonight...
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Wed May 12, 2004 5:03 am
Mike,
I got the data files last night and I have the RVAF3 working but it still drops logs... I'm at a loss... I dont know of anyone right near me that has a laptop I can borrow to test...
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Wed May 12, 2004 4:11 pm
MIke,
Got the file Thanks. I have all of the correct scalers from what i had before but the data logging is still fritzy. Is there anything I can try, IE install win 98 instead? I need to get this fixed.
Terry
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Wed May 12, 2004 5:35 pm
Here is something...
When I try to install BDE I get a "Error createing/opening registry key" Could this be my problem??????
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
93notch
Post by 93notch » Wed May 12, 2004 11:45 pm
Tim,
Send me a zipped logfile and read your calibration back from the tweecer so it has the payload in it. Let me check and see wtf is up with this turd.
info@tweecer.com
Best regards,
Mike Glover
tms217
Post by tms217 » Thu May 13, 2004 5:40 am
What do you need here? I can get you anything you need. I guess I dont know how to do this..
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
93notch
Post by 93notch » Thu May 13, 2004 12:42 pm
Sorry. Read the TwEECer position that has the binary where you are trying to datalog from. Save it to a file and email it to me. When you read it from the TwEECer, it will have the payload in it and I can look at the file and make sure that the payload is being written correctly.
Best regards,
Mike Glover
tms217
Post by tms217 » Thu May 13, 2004 1:49 pm
email sent..
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Sun May 16, 2004 5:20 pm
Mike I just sent you a full 1/4 mile run and you can see more of the issues. You can see some of the logs are as few as 1-2 logs per second. Even at idle it skips so this is not just a WOT issue..
Terry
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Tue Jun 22, 2004 2:33 pm
Mike,
We had tried to work out the issues I was having with my Tweecer skipping datalogs. I pulled it out and cleaned all of the contacts to try and find my problems. I wanted to see first off if I sent it back to you if you could see if it might be a possible hardware issue and if it is we can try to do something about it.
Second, I wanted to see if I could send my autologic chip with it to get the program of off it. Please let me know as soon as you can.
Terry
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Fri Jun 25, 2004 11:26 am
Update...
I took out the tweecer and installed it onto a 1989 5.0 with a A9M ECM. The datalogging works like a charm. Put it back onto my Cobra and it gets jumping around again. Is the tweecer data logging not compatible with the 2001 Cobra?
Terry
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
slowbra
Post by slowbra » Fri Jun 25, 2004 3:35 pm
I suspected it would work fine on another car since the chances of you and I both having identical computer/USB/connection problems was slim to none.
2007 Acura TL-S
1998 Chrome Yellow Cobra
1987 Mustang LX Notch
tms217
Post by tms217 » Tue Jun 29, 2004 5:38 am
Is there a plan to fix this for the 2001 Cobras?
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
Chris Mureen
Post by Chris Mureen » Tue Jun 29, 2004 12:16 pm
It isn't just 2001 Cobras. My 98 AOL3/CRAJ0 has always had the same problem.
Dale McPeters
Post by Dale McPeters » Tue Jun 29, 2004 1:13 pm
Chris Mureen wrote:It isn't just 2001 Cobras. My 98 AOL3/CRAJ0 has always had the same problem.
This would also be the same on '01 GT w/GIZ2 2 or 4 bank using the RVAFA strategy....with Alpha A9xx. This would be using a known "GOOD" TwEECer from my '03 Mach 1............
I can not get it to datalog anything but garbage.............
BE & EEC Analyzer
Paul's EEC-Editor
tms217
Post by tms217 » Wed Jun 30, 2004 1:50 pm
Does this mean that there will be a fix for this?
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
tms217
Post by tms217 » Fri Jul 02, 2004 4:45 pm
Is the silence a yes its being worked on or no its not?
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
Dale McPeters
Post by Dale McPeters » Tue Jul 06, 2004 8:18 am
tms217 wrote:Is the silence a yes its being worked on or no its not?
I can not answer this as I have not heard from Mike G. in a while. I have been very busy working on my own "stuff". Have you emailed Mike directly to see if he has come up with a fix yet?
I still could not get the '01 GT that I was "tinkering" with to datalog corrctly. I know that he was looking into this isssue but have not heard anything yet......
Dale
BE & EEC Analyzer
Paul's EEC-Editor
tms217
Post by tms217 » Tue Jul 06, 2004 4:22 pm
I got an email from him today... Sent him alittle info back.
1988 Notch 306
1999 Lightning
2012 BMW S1000RR
