TT331FB
Sealevel load vs RPM scaling for with boost, best practice
Post by TT331FB » Wed Apr 27, 2005 11:20 pm
Hi Tuners,
Whats the concenses on adjusting the scaling to make the max load equal 100% load x. In other words, If I am seeing load values of 160%, should I scale them down to 100% load X?
TT331FB - T3/.6/.63 turbos, Spearco intercooler, 302/331 Mexican Block,AFR185, 80mm MAF, 75mm TB, 50# injectors, TFS intake, Comp cams roller blower grind, DIY-WB, Yokogawa video display,T-56 tranny, 9" 3.5:1 Trac-lock A9S, RT
SHaFT7
Post by SHaFT7 » Wed Apr 27, 2005 11:38 pm
I just did a 3rd gear pull and then popped it into eec analyzer.....put my loads right where they need to be :D
91GT, TwEECER R/T, A9L mods
back to NA H/C/I for now, turbo combo coming this fall!
02 ZX-6 - stock
TT331FB
Post by TT331FB » Thu Apr 28, 2005 8:59 am
Thanks.
Please clarify if you ended up with loadx(%) no greater than 100%, even under boost.
pthornton
Post by pthornton » Thu Apr 28, 2005 9:05 am
Really depends on what you want to do. My supercharged car is seeing loads in the 150-160 range. It doesn't really matter though as I want the exact same timing and AFR from 100% load and above so why change the load scaling? If you want to control how much timing comes in at 120% vs 100%, then rescale. Yes, you can easily scale so that you see 100% load as the peak loadx. EEC Analyzer makes it easy to visualize the changes on a graph.
Cobra Intake / AFR 165 Heads
CompCams 270H Camshaft
1989 Saleen Coupe # 653 *****
TT331FB
Post by TT331FB » Thu Apr 28, 2005 10:14 am
Then do I understand correctly that you have not rescaled the load at all? What is your OL switch point?
My WB shows that I am still in closed loop when I start making boost leading to some "ping". My OL switch point is 75% loadx or 3VDC TPS signal. I make boost by 2800 RPM.
Dale McPeters
Post by Dale McPeters » Thu Apr 28, 2005 11:47 am
TT331FB wrote:Then do I understand correctly that you have not rescaled the load at all? What is your OL switch point?
Randy, Has rescaled his load. I have the OL_Throttle_BP set to 2 & the WOT TPS Breakpoint voltage set at 2.5 under the scalar tab on my '93 A9L/GUFB car.... I have also adjusted the sea level load scaling.
One thing that you may consider looking at is the Min Load For Open & Closed Loop Fuel Control under the Scalars tab............These can be changed to make it look at the open loop fuel tables sooner.
Off Topic - What is the model number of the Yokogawa Display that you are using? I have looked on their website but do not see anything that looks like what you have mounted in the car......
BE & EEC Analyzer
Paul's EEC-Editor
TT331FB
Post by TT331FB » Thu Apr 28, 2005 12:17 pm
The data logger is a DX100, customized to run on 12VDC. This is a trick part but way to exspensive to buy. It would be close to $3k if you bought it. Turns out the product manager is a Mustang dude and he was happy to supply me with a out of date unit. It works great for what I need but the "Bling" factor is what catches the eye. "no, it's not a DVD screen, its a data logger" LOL
Dale McPeters
Post by Dale McPeters » Thu Apr 28, 2005 12:54 pm
TT331FB wrote:The data logger is a DX100, customized to run on 12VDC. This is a trick part but way to exspensive to buy. It would be close to $3k if you bought it. Turns out the product manager is a Mustang dude and he was happy to supply me with a out of date unit. It works great for what I need but the "Bling" factor is what catches the eye. "no, it's not a DVD screen, its a data logger" LOL
I found the part number for it after reading your write up on your website. The reason that I asked about it is a friend of mine had offered me a used one a while back but I am not sure what the model number was on it. Now I have something to compare it with.... :D Yep the bling factor is very nice on that one, also a very nice car by the way. Maybe my '65 coupe will grow up to be that nice one of these days.... :lol:
BE & EEC Analyzer
Paul's EEC-Editor
Users browsing this forum: Bing [Bot], Google [Bot] and 128 guests
