Server issues as of late...
Ok guys, I have been having some hardware issues that began late last week around friday. I am currently building a new machine to host this site on.
Thank you for all that have been patient. I didn't know about the outage till yesterday morning.
I will keep everyone up to date on the current status of the site as things progress.
-Jon / Owner
-Jon / Owner
We were noticing DNS issues as well with the toilsoft.com domain expiring.
Yep that was the initial cause for failure, but that was a quick 30 second fix. DNS issues have been resolved and now there are instability issues related to (i think) the memory or motherboard.cgrey8 wrote:We were noticing DNS issues as well with the toilsoft.com domain expiring.
That machine is due for an upgrade so I've decided just to swap it out with a new box i am hopefully going to get to piece together tonight.
-Jon
Even in it's problematic state, it seemed faster than this machine. Surfing around the forum now seems much slower running on this machine.
I admin a phpBB forum for my company, but there's only internal employees that log into it. It never gets webscraped, or attacked, or anything like that. Point being, it runs on a 2.4GHz machine and it flies. But that's with me sitting with it on a 100baseT network and it has no other duties other than serving up that forum with no more than 2-3 people logged into it...ever. This forum was almost as fast on the previous machine, going over the Internet. But now, it's noticeably slower especially when posting updates to threads.
BTW, while you have the hood up on this forum and the server serving it, you might want to check out the phpBB forums for the error we kept getting a few weeks back about the MySQL table "sessions" getting too full. There's a php fix for this over there. It seems when the webscraping bots like Google and Yahoo come along to cache the pages, they use invalid session IDs that get inadvertently entered into the sessions table and don't get purged before the table gets full. What the code mod does is resizes the table when it gets full. Juse make a search on the phpBB forums for:
SQL Error : 1114 The table 'sessions' is full
You'll find the thread with the code fix AND some further comments about what happened to some people after the fix was implemented and how they had to deal with it.
There's also some good threads about ways to modify the php that catch the auto-registering bots that constantly spam this forum. Thanks to 2Shaker, this isn't as big of an issue for the rest of us anymore, but it's because he is cleaning crap out of the discussions multiple times a day.
BTW, thanks for taking the time to get us back online. We use this site quite a bit and we missed it when it was down.
And ditto again, thanks Jon. And if you could do something to reduce the SPAM it would be terrific. I did notice that since it was down I haven't had to remove any.
Jon,
What's the server status?
Site's back up and responding very snappy.
Yep, I used my lunch break today @ work to run up to the colo and install the new hardware, so that is the reason for the snappier response.
Everything should be good to go, so let me know if anyone sees any problems.
Sorry it took so long guys/gals.
Jon
Jon
Is it a dedicated server running the site or do you have it Virtual Hosted with other websites using the same webserver?
BTW, navigating around the site goes pretty smoothly, but it seems submitting responses takes a little long. It's not unreasonable, but it is taking an extra few seconds longer than I'd generally expect. I don't know what that's about, but I thought I'd mention it since I noticed it.
And thanks again for taking your lunch break to do that.
I'll look into the posting issue as time permits. The site is hosted on its own server. No virtualization is happening on the hardware it runs on. I might end up moving the sql process to its own hardware as well...but I will let you guys know what I do to fix the posting speed issues when it happens.
Jon
Jon
twinturbostang
Wow, it lives! :D
www.twinturbostang.com
Thanks for getting the site back up Jon... definitely felt beside myself without being able to get on for some assistance.
306 (stock block),TFS Track Heat Heads, E303 Cam, TFS track heat intake, 70 mm TB, 75mm Pro-M,42 lb injectors,Aeromotive AFPR, 255 lph intank, Crane Hi-6/LX-92. Turbonetics 60-1 hi-fi
A9L using Binary Editor
- Ed Hohenberg
I'm still seeing this often, FYI. Other than that- it appears to be running good.sailorbob wrote: Bad news:
I keep seeing the "The table 'sessions' is full" too, it seems to be becoming a daily occurrence
Thanks for the great site!
1990 LX 5.0 'Vert A9P GUFC BE/EA
Mods: 6psi Powerdyne w/UPR fender kit, offroad H pipe, dynomax mufflers, 3.73's, AOD w/3200 stall.
Stock: Everything else, including: MAF, H/C/I, 19lb Injectors, etc.
13.19 @ 103 on 2.00 '60 (street tires)
stanger007
Jon - could you switch the sessions table from a Heap to MyISAM or increase the row limit on the Heap table? Lastly, a scheduled script to clear out the old sessions would fix this as well.sailorbob wrote:Good news:
It's great to have the forum back :D
Bad news:
Let me know if I can help out with anything.
Wes
'95 GT Auto - CBAZA 'vert [11.01@127.65 on 154k stock shortblock]
'72 Mach 1 - A9L EFI Conversion Complete, FAST ECM/331/Turbos next
'07 GT Auto [12.86@107 Tune/Boltons]
Total Performance Solutions Dynotuner
There's a php code patch on the phpBB forum for fixing this. It just needs to be applied to the code that manages the sessions. But yes, doing this at the db level would also be useful. This error is getting quite frequent...
I have upgraded to the most recent version of phpBB, need to update the templates soon so for now we will suffer with the default template.
Starting work on updating...new content coming...its been waay too long.
You guys let me know if you see anything critical...
(PS: RSS feed coming back soon.)
I'm still getting the Sessions table full errors like clockwork every single morning and sometimes infrequently during the day.
I keep getting this
phpBB : Critical Error
Error creating new session
DEBUG MODE
INSERT INTO sessions (session_id, session_user_id, session_start, session_time, session_ip, session_page, session_logged_in, session_admin) VALUES ('f22f09031dd0271aee3a31e100c33398', 2711, 1189651789, 1189651789, '18b3f519', -2, 1, 0)
Line : 187
File : sessions.php
DEBUG MODE
Line : 187
File : sessions.php
Yeah, that's the same annoying error the rest of us are getting.
meatheadmike
Users browsing this forum: No registered users and 126 guests
