tealstang67
Re: Moates Quarterhorse (prev. known as Pegasus)
Post by tealstang67 » Fri Feb 20, 2009 8:17 pm
Are they open tomorrow does any one know? I will also need to know which wide band is okay for a budget ( LC-1 Kit - P/N: 3795) Is this one a good one? My computer is a eec IV isn't it? I would like to go ahead and get the switch craig talked about also. THANX
94 gt, CBAZA/T4M0,Kenne bell blowzilla(8#boost)now with a custom a2a inter cooler,E cam,E7's (mildly ported),1.72 rockers,306wdss dish pistons,eagle h-beam rods,dss girdle,bbk long tube headers,42# injectors,HPX slot maf.Quarter Horse, LC-1 wideband
67 coupe,408 probe ,AFR 220,13.2-1 comp,CBAZA T4M0, Powerglide, 235 Drag Radial, Leaf Spring
Car has been the best of 5.59@125.6 with a 1.28 short time
http://www.coretuning.net
SigEpBlue
Post by SigEpBlue » Fri Feb 20, 2009 8:24 pm
Um...they're open all the time online, mang. 8)
"Budget" and "wide-band" are two words that can seldom be used in the same sentence, but I think others' input would probably be more helpful. Yes, you're EEC-IV, and IIRC the 'switch' isn't an option right now on QH.
1993/4/5 Full-Size Bronco:
  • Original F4TE 5.8L short block, transmission, & drive train w/ 210,000 miles
  • GT40P heads, intake, & headers; custom exhaust, Mustang cam, BIO0 PCM, Moates QH
  • ~15/22 mi/gal in a 5000-lbm tool shed
  • Driven daily, built with pride, all with US-made factory parts!
svojohn
Post by svojohn » Fri Feb 20, 2009 8:53 pm
Do we need to download a newer version of BE?
lito
Post by lito » Fri Feb 20, 2009 10:02 pm
tealstang67 wrote:Are they open tomorrow does any one know? I will also need to know which wide band is okay for a budget ( LC-1 Kit - P/N: 3795) Is this one a good one? My computer is a eec IV isn't it? I would like to go ahead and get the switch craig talked about also. THANX
If you want a WB that can be trusted and relatively cheap get an NGK powerdex AFX.
Post by cgrey8 » Fri Feb 20, 2009 10:09 pm
Since you are talking affordable, you also need to keep in mind that BE can interface directly with the Innovate LC-1's serial connection, thus you don't require a DataQ A/D converter to datalog the WB along with your QH. Any other WB would require a DataQ to interface and be datalogged with BE.
The one thing I can say about the LC-1 is it datalogs slow, but fast enough. However if you are looking for high speed datalogging, you might still want to invest in a DataQ just to get higher logging rates. If you do decide to use a DataQ, then whatever WB you choose will be just fine.
tealstang67
Post by tealstang67 » Fri Feb 20, 2009 11:01 pm
how much are data Q where do i look at them?
Post by cgrey8 » Fri Feb 20, 2009 11:07 pm
Google DataQ. The DI-148 is the USB-version that's around $50+s/h.
There's a cheaper version that's $25, but it's RS-232, instead of USB. So just like with the LC-1, you'd need a USB-to-232 converter OR have an available RS-232 on your laptop. Really expensive laptops or older laptops still have them. But most laptops today simply don't have them.
tealstang67
Post by tealstang67 » Fri Feb 20, 2009 11:24 pm
My laptop has many older style connections how would i know which one might be rs-232? Although if the lc-1 has all i need that will probably be the one for me it is also one of the least expensive ones. Thanx for the help.
Post by cgrey8 » Fri Feb 20, 2009 11:55 pm
An RS-232 serial connection is a 9-pin D connection.
Cougar5.0
Post by Cougar5.0 » Sat Feb 21, 2009 9:11 am
cgrey8 wrote:An RS-232 serial connection is a 9-pin D connection.
I was curious about the RS-232 standard, so I looked it up and noted that it originally recommended a DB-25 connector, but obviously the DE-9 (commonly mistakenly called the DB9) is the only connector you'll see on any PC/laptop these days.
428w now
tealstang67
Post by tealstang67 » Sat Feb 21, 2009 9:55 am
my laptop is about 8 years old. it has 6 different pin plugs plus one usb
Foxfan88
Post by Foxfan88 » Sun Feb 22, 2009 10:12 am
so are we waiting for a BE update from clint or is it already up and i am missing it?
i havent got any update windows come up when i load up BE. but i did see a new REV 44 defitnition for download on clints site.
can someone set me straight, i got my QH ordered, cant wait to get to tuning with it
Brett
91 mustang gt 5.0 c4 auto
a9p ECU running GUFB strategy
TFS twisted wedge heads, f-cam, typhoon intake.
Moates QH using BE/EA
70mm single turbo setup.
86GT
Post by 86GT » Sun Feb 22, 2009 12:47 pm
Foxfan88 wrote:so are we waiting for a BE update from clint or is it already up and i am missing it?
The BE software that supports the QH is up on the site. Since there were some major revision, you will need to uninstall the version you have and then install the one from the web site. The def files have been updated too. Not all def files are supported yet but the GUFB is. You will see the download page has changed.
It also appears that craig is making some last minute updates to the QH. I will need to get BE caught up. The update is for multiple tune capability. The single tune portion should be untouched i believe.
David Claflin
Post by David Claflin » Sun Feb 22, 2009 7:22 pm
Foxfan88 wrote: i got my QH ordered, cant wait to get to tuning with it
X2, have to get BE in the next couple weeks too.
1990 LX/A9L/302, Ported RPM heads, Ported Holley SMII, 1 3/4 longtubes, 3"exhaust, T5, 3.73
1985 LTD LX, A9L, ported TW heads, ported Holley SMII,1 3/4 longtubes, 4.10, T5trans, mach 1 brakes.
1986 coupe, A9L, former FHP car, stock shortblock, TW 11R190heads, stock cam +4, VIC Jr EFI. 4-holeTB, Pro-M Duo, 2 slotmeters, 1 3/4 longtubes, 3" exhaust, T5Z, 4.88
1993 LX A3M, 347, 11R205 heads, Ported Holley SMII, 1 3/4 RCI headers, 3" exhaust, 4.10s
cherrybomber22
Post by cherrybomber22 » Sun Feb 22, 2009 9:25 pm
i ordered my QH the second i saw it on the site
i am reading and you are saying we need to uninstall the old be
what about the unlock code
95' mustang 289cid,NA,8.5:1 comp,E7 heads,A9L,moates,BE
94' mustang 5.0 stock W/hot tune T4MO,moates,BE
91' mustang 5.0 stock engine 12.799 at 103.8 A9L.moates,BE
Post by cgrey8 » Sun Feb 22, 2009 9:47 pm
Don't get rid of your *.lic license file. Keep that. So don't uninstall then delete your old install directory. Just uninstall. The uninstall process shouldn't delete that *.lic file. But it would be a good idea to have a few copies of that file just to make sure you don't loose it.
Cantedvalve
Post by Cantedvalve » Mon Feb 23, 2009 10:55 am
tealstang67 wrote:how much are data Q where do i look at them?
I have a spare (DI-148 USB version - got it with my TwEECer) if you are interested. Cut you a smoking deal on it :)
1970 Mustang w/ STOCK 351C-2V
Novi 2000 Supercharger - 5PSI boost
Art Carr AOD - 2500 stall
A9P-driven EFI
tealstang67
Post by tealstang67 » Mon Feb 23, 2009 6:42 pm
I ordered my QH and wideband i hope i can buy be and ea soon. Hopfully i will get this sucker tuned in a adequate amount of time. 8)
Foxfan88
Post by Foxfan88 » Mon Feb 23, 2009 7:42 pm
i dont know if its just me but i am real EXCITED about the real time tuning capabilities. its happened quite often where i am wanting to make a SMALL tweak and be able to note the change. like a maf tweak at idle or something. but with the tweecer usually the car will stall or hiccup as it switched to the stock tune, so i lose the stabilized condition at idle.
it should make the initial dial-ins with maf, slopes and offsets etc go alot smoother, will be able to hammer in values and try them out real fast to find whats going to work.
Brett
Post by cgrey8 » Mon Feb 23, 2009 7:46 pm
That's right.
Seek
Post by Seek » Mon Feb 23, 2009 9:19 pm
Foxfan88 wrote:i dont know if its just me but i am real EXCITED about the real time tuning capabilities.
This is how things "should" always work... at least in my opinion. I know our EEC's are "old" compared to today's standards but with what we can do today in terms of technology, it's about time someone releases a product that can do this. On top of that, they managed to make it so we can datalog more than anybody else - I love it. After thinking it over, I came to the conclusion that I likely won't be touching multiple tunes as power and efficiency/economy go hand in hand. For emissions testing, I figure just upload a new tune (new engine should pass without issues but a little extra can't hurt). Keep a spare stock BIN on hand and there isn't a need for a home tuner to need to read the stock settings from the EEC.
Overall, on paper this looks like a great product. Hopefully it'll arrive soon so I can yank the TwEECer and get the EEC all the way back in its hole.
'88 Thunderbird - 306 with '89 HO cam, 54cc TW170 heads, GT40 (ported) intake, 24lb injectors, 70mm Accufab TB, 75mm Pro Flow MAF, dual 2 1/2" exhaust run by an A9P ecu and Moates Quarterhorse. Bolted up to 4r70w with PI 9.5" 3k stall converter and 3.55 8.8" rearend.
SigEpBlue
Post by SigEpBlue » Tue Feb 24, 2009 10:57 pm
EDIT: Nevermind, apparently it magically transported itself to Michigan today. Craig you are amazing. Not only can this thing tune our PCMs, but apparently you've integrated teleportation technology as well. Kudos. :mrgreen:
New Coolness wrote:Package Progress
WYOMING, MI, US
02/25/2009 7:32 A.M. OUT FOR DELIVERY
02/25/2009 7:10 A.M. ARRIVAL SCAN
LANSING, MI, US
02/25/2009 5:47 A.M. DEPARTURE SCAN
02/25/2009 5:06 A.M. ARRIVAL SCAN
LOUISVILLE, KY, US
02/25/2009 3:59 A.M. DEPARTURE SCAN
02/25/2009 12:23 A.M. ARRIVAL SCAN
JACKSON, MS, US
02/24/2009 9:56 P.M. DEPARTURE SCAN
02/24/2009 8:27 P.M. ARRIVAL SCAN
02/24/2009 8:25 P.M. DEPARTURE SCAN
02/24/2009 1:47 A.M. ARRIVAL SCAN
PORT ALLEN, LA, US
02/23/2009 9:53 P.M. DEPARTURE SCAN
02/23/2009 9:16 P.M. ORIGIN SCAN
US
02/23/2009 6:43 P.M. BILLING INFORMATION RECEIVED
Old UPS Tracking Status wrote:Your package is in the UPS system and has a rescheduled delivery date of 02/26/2009.
Location Date Local Time Description
JACKSON, MS, US
PORT ALLEN, LA, US
A6intruder
Post by A6intruder » Tue Feb 24, 2009 11:17 pm
Wes,
Any issues installing the QH on the T4M0 computers? I think you do a lot with the CBAZA EEC's?
Dan Nicoson
1994 Mustang GT, CHP 331 forged crank bottom end, single Holset HX35W turbo, AFR 165 heads, TF Intake, "Baby" Crower cam with Beehive springs, TwEECer using BE and DataQ data logger
SigEpBlue
Post by SigEpBlue » Wed Feb 25, 2009 3:52 pm
...and guess why? :mrgreen: Thanks for the presents too, Craig! You are better than all right in my book. Image
Good choice on using the Xilinx XC95288XL CPLD, btw.
EDIT: For some reason, there was a Ford binary already loaded onto my QH...? My guess is that it's there from testing; it was dated FoMoCo 2002 in the last few bytes of the binary. Good to know you guys tested these. My compliments on the cleanness of the PCB layout. What are you guys using for PCB design, btw? I've used EAGLE with great success for a 3-phase BLDC board I made based on a PIC18F, but I don't know what else is really out there in the "real world."
I wish I could say that I've plugged it in and have run it, but I'm intermittently writing a persuasive essay that's due tomorrow. :roll:
Seek
Post by Seek » Wed Feb 25, 2009 3:53 pm
SigEpBlue wrote:EDIT: Nevermind, apparently it magically transported itself to Michigan today. Craig you are amazing. Not only can this thing tune our PCMs, but apparently you've integrated teleportation technology as well. Kudos. :mrgreen:
Mine won't come until Monday :(
BobCat
Post by BobCat » Wed Feb 25, 2009 4:49 pm
Showed up today and it works flawlessly :cheers:
STLMustangs
Cantedvalve
Post by Cantedvalve » Fri Feb 27, 2009 4:22 pm
Are the definitoin files different from QH to TwEECer?
A9P-driven EFI
86GT
Post by 86GT » Fri Feb 27, 2009 4:51 pm
Yes they are Look for the def file that does not have a rev number in the name. The rev numbers are now inside the def file
cougarnut281
Post by cougarnut281 » Fri Feb 27, 2009 10:43 pm
SigEpBlue wrote:
WYOMING, MI, US
You live in the Grand rapids area too? Talk about a small world.
SigEpBlue
Post by SigEpBlue » Fri Feb 27, 2009 11:59 pm
Yup. For the moment. :mrgreen:
I'm originally from Ida, a small farm town in the south-east corner of the state. I've been at GVSU for a few years (hopefully not too many more), pursuing a BS in electrical engineering, and I'm living in Jenison now. This side of Michigan is much more....alive than the other, I'll leave it at that. lol
