The switch was originally on the metal High Pressure Line leading out of the P/S Pumproh92cp wrote:.... I have tried to add rpm at the idle rpm adder for power steering and I've enabled the power steering pressure switch present, but I'm not sure the 92 mustang has an electronic pressure switch on the steering rack.
korywiesner
Re: Idle issue..Crank..starts..stalls
2000 GT w/2.9 Whipple on 04'SVT 4.6,T56 6-Speed,Suede cobra interior,QA1 K-Member, control arms,bump steer,camber/caster plates & coil overs.80mm Inj,LP Dual FPDM,160mm TB,MAFia.19"Twisted Vista Polished Wheels,Eibach in rear, Wildwood 6 piston up front, Baer in back. Innovate WB, Pioneer AVIC-N4 W/ Bluetooth, Fosgate amps, speakers, and subs. Cervinis hood, skirts, ducts and trunk. 04 Cobra Nose
I'm done with this issue, for a month I have had stall free driving. I do have a idle hang issue when the car is warming up but other than that I think I've put this issue to rest. I'll post up what changes I made to get me there.
BE/EA Moates QH, A9L GUFB. 92 DART363 custom cam, KB Customs inlet 2.8L H series, custom A2A intercooler 20psi, Trick Flow R lower TW 205cc heads, 60 lb injectors, HPX slot style MAF blow through, custom 5" intake, 105mm T/B, 340lph intank and KB BAP, Crane HI-6R. Zeitronix wideband. J&S Safegaurd system.
"The sound is unnatural and not of this world, like a screeching velociraptor with the flames of hell licking it's ass"
- Green-Jimmy
Glad to hear its been running good. I"ve read through this post a few times recently, so please post all your findings!
1992 5.0 LX - 363 Dart Block, AFR185, 60lb Injectors, 80mm PRO-M MAF, XE274HR Cam, Edelbrock RPM2, GForce T5, 3.73, BBK 1 3/4, 3" VRS Catted X-Pipe, A9L, GUFB, Tweecer RT, BE, EA, LM-1
lol, what did you end up changing? I've had issues with idle stalling on declutch for a while now.
1992 mustang, 302, gt40p heads, f-303 cam, edelbrock performer rpm II intake, bbk 70mm TB, bbk CAI with a C&L 76mm MAF, 1 5/8 shorty headers, stock ratio rockers, no a/c, no smog, 42lb injectors
Single HX40w turbo, jgs 50mm BOV and jgs 40mm WG
GUFB, A9L, moates quarterhorse, BE/EA, innovate lc-1 wideband
Back from the dead, but since this issue started with the addition of my custom KBA2A setup with the stock 302 I have since split that block and have rebuilt with a Dart based all forged 363 with the custom A2A setup. When the new motor went in this spring the same stalling issue resurfaced and I went on the war path again to root it out and have again attained a steady and reliable idle and transition from part throttle. It's rare but the only time now I get a stumble and conk out is when backing out of my gargage and rolling in reverse when I clutch and brake to stop and move forward it want to stall. But all other stalling or conking is gone. The last thing I did that seemed to have the most significant effect on this was idle-ISC adder vs RPM and below is what I changed.
Here is my new Dart KB363 with custom A2A.
Great looking setup! I've yet to intercool my Blowzilla as well, but one of these days. I have also had to mess with the ISC Adder to aid the engine at low RPMs and it's quite effective. Are you running an 8-rib setup by any chance?
Hi Shaker, yes I have an 8 rib setup. ASP custom made 7.5" crank pulley $275, ASP custom 2" KB blower pulley, Stock 93 Cobra water pump pulley and a used 93 Thunderbird SC power steering pulley. I have no smog or A/C.Shaker666 wrote:Great looking setup! I've yet to intercool my Blowzilla as well, but one of these days. I have also had to mess with the ISC Adder to aid the engine at low RPMs and it's quite effective. Are you running an 8-rib setup by any chance?
If your interested in a custom made A2A KB intake like mine, I made one for Clint Garrity AKA 86GT about 1 year ago and I believe he still has it. He has not used it and may be willing to sell.
Users browsing this forum: Bing [Bot] and 49 guests
