jestang
GUFB - BE - What does Flag 6, bit 0 (FLAGS6_B0) represent?
Post by jestang » Fri Oct 14, 2011 8:35 am
I'm trying to diagnose a misfire/stutter problem I'm having and I noticed that flag 6, bit 0 is being set right around when I'm having my problem. I'm sure someone on here knows what this is or can somehow figure it out. Thanks guys.
91 Ford Mustang
347 on e85, 76mm turbo, pmas hpx mass air meter in 3" tube w/maf extender, fox lake stage 3 ported trickflow heads, custom turbo cam by comp cams, trickflow box r intake, 75 mm tb, ID1000 cc injectors, tko600, triple walbro 255 external pumps, moates QH, GUFB, 15 psi, 200A alt, LC-1 wideband
Re: GUFB - BE - What does Flag 6, bit 0 (FLAGS6_B0) represen
Post by cgrey8 » Fri Oct 14, 2011 8:41 am
If I knew, it'd be in the def file. However hopefully one of the resident BIN hackers might know. Since this truly is an EEC code question, I'm moving this thread over to the EEC Geeks area. If anybody figures out what that flag is and can give it a name, I'll update the def files to reflect that knowledge.
jestang
Post by jestang » Fri Oct 14, 2011 9:35 am
Thanks chris .... wasnt sure exactly where to post this question. I searched the def file but didnt have any luck so I was hoping one of the hackers might know or could find out.
91 Ford Mustang
Post by decipha » Fri Oct 14, 2011 7:13 pm
just curious
are you using the ecu's fan output? or possibly have the fan enabled in the tune?
jestang
Post by jestang » Sat Oct 15, 2011 9:54 am
decipha wrote:just curious
I have a wire pinned to the ecu harness to eventually use it but I am not using it at the moment and it is disabled in the tune.
91 Ford Mustang
mpaton
Post by mpaton » Sun Oct 16, 2011 2:55 pm
latch for the LDMH comparison on p6-20
jestang
Post by jestang » Sun Oct 16, 2011 10:39 pm
mpaton wrote:latch for the LDMH comparison on p6-20
could you dumb that down for me a bit please? lol
91 Ford Mustang
Post by cgrey8 » Mon Oct 17, 2011 5:47 am
I think that might be a page number in the GUFB strategy doc. Check the Tech Docs section of the forum for a copy of it.
jestang
Post by jestang » Mon Oct 17, 2011 8:53 am
cgrey8 wrote:I think that might be a page number in the GUFB strategy doc. Check the Tech Docs section of the forum for a copy of it.
Got it ... Doesnt seem like I met all the requirements for the lugging flag to be set though .... load was in the correct area but thats about it
91 Ford Mustang
